Compression question. - Ford Powerstroke Diesel Forum
Old 02-10-2009, 10:27 AM
Cynic
For those of you who HAVE tested the compression, I have a question...
Have you seen valve\valve seat damage and still had decent compression (above 390psi)???
Engine was tested at ambient outside temp.
Very little to no oil leaked into the cylinder when glow plug was removed.
Pressures held for 2-3 min before gauge was removed to move the the next cylinder.
Old 02-10-2009, 10:42 AM
The Screwy HEUI
Have you seen valve\valve seat and still had decent compression (above 390psi)???
Dirk, forgive me for hijacking your thread, but do you have a p/n for the adaptor to run a compression test? If you tell me, I can answer your question!
Old 02-10-2009, 10:53 AM
Cynic
I don't know. Call Diesel Innovations.
International Threat
I run the compression test and usually give it 3-5 cranks to get the compression and then move on. I don't let it sit there because the gauge I use takes the maximum value achieved and holds it there.
Old 02-10-2009, 10:58 AM
Cynic
right. So does mine. I'm just questioning the state of the valves\seats due to issues I'm having.
Old 02-10-2009, 11:02 AM
ok gotcha .
Old 02-10-2009, 12:37 PM
Cynic
bump to the top.
Old 02-10-2009, 04:01 PM
Cynic
another bump
Old 02-10-2009, 04:22 PM
Jon
Guest
Posts: n/a
I havent.
Lifetime Premium Member
Heres a bump for ya..cant answer that one.
