Injector install no start please help - Ford Powerstroke Diesel Forum
Old 02-10-2009, 06:30 AM
I just changed out my injectors in my 2000 Excursion and now it wont start. I cranked it till the batterys died. it toasted my starter.I replaced both of the under valve cover harnesses and made sure everything was plugged in. I pulled the sensor out of the top of my hpop res and it was full of oil. i dont know what else to check. Please help this is my last day off from work and my truck is the only vehicle i have.
Old 02-10-2009, 06:33 AM
The Screwy HEUI
Is your fuel bowl primed? Fuel pump OK? Your next best bet would be to scan for codes & see what your rig tells ya.
Old 02-10-2009, 06:36 AM
The fuel bowl has fuel in it I checked by opening the drain valve. I noticed that after I start cranking it for a while I start to hear a ticking noise towards the front of the motor up top. Is this normal
Old 02-10-2009, 06:37 AM
Also the truck ran fine before I pulled the injectors so it must be something i did. Maybe I just have to crank it longer. I heard that it takes a while to get oil to the injectors.
The Screwy HEUI
Ticking noise? I'm not sure about that. I don't hear it in mine(but I'm still running stockers). Let's see if a tech can help. Do you have access to a scan tool?
Old 02-10-2009, 06:39 AM
The Screwy HEUI
This is a possibility, also. But considering it's a high pressure system, the rails would've already been primed. Lemme see if I can find a tech.
Old 02-10-2009, 06:41 AM
Thanks the only type of scanner I have is my hypertech programmer it just pulls codes
Old 02-10-2009, 06:42 AM
International Threat
Did you take the oil galley plugs out? Forget to put them in?
Have you cranked for 10 seconds 1-2 minutes apart about 3 to 5 times? With a battery charger on the batteries and a multi meter on them making sure you're cranking at 12 volts.
Any codes?
Old 02-10-2009, 06:43 AM
I did pull the plugs out of the rails and let them drain before i pulled the injectors. I made sure to put them back in place when I was done. Is it possible that there is an air pocket in the rail maybe
Old 02-10-2009, 06:44 AM
I didnt crank it for 10 seconds one to two minutes apart though. I just cranked it. What does that do?
