How embarrassing is this? - Ford Powerstroke Diesel Forum
post #1 of 75 Old 02-10-2009, 04:20 AM Thread Starter
symbols's Avatar
Ok. So I have a daycare next door to me and after they built some new houses on the other side they moved their stinky azz dumpster on my side because of accessibility issues. I can deal with the stench and I'm used to it now for the most part. What I can't deal with is waste management coming by at 4 am and dumping it 50 ft from my window. My neighbors and I have called and complained several times but it obviously hasn't worked. So when I got my unwelcomed wake up call this morning I decided I was going to give them a taste of their own medicine. So I drive by their shop about 6 am where there must have been about 50 people standing outside and let the train horns loose. Immediately after that my truck dies. So I'm sitting in front of their building with everyone that I just scared the piss out of staring at me while I'm trying to restart my truck
So I need help figuring this horn issue out. I've had this problem since I installed them. I've triple checked my wiring and nothing seems to be wrong there. I pulled the air actuator valve and replaced it with a test light and WHALA issue is gone. So I get them to send me another valve. I install it and same issue. So I get an Ingersall Rand valve from grainger and install it. Problem fixed. Fast forward 3 months to now and the issue is back. I don't blow any fuses and all I have to do is cycle the key and it restarts and runs fine until I push the button again.
Any ideas?
Jason
"Using a thug's murderous rampage to call for gun control is like using Barack's reckless spending to call for higher taxes."
--Michael Berry, American philosophizer & Talk Radio Czar, 1970-?
symbols is offline
post #2 of 75 Old 02-10-2009, 04:27 AM
szyd's Avatar
Serves you right!!!!!!
Man isn't that just a bad feeling when you do something and it back fires.
I don't know anything about train horns.
Dale
99.5 F 350 Totaled
2000 F350 Lariate
CC
SB
4x4
4" turbo back
cold air. Zoodad
Banks big head
Wicked wheel
4" BDS lift. With Bilstein's
all brought together by TW
szyd is offline
post #3 of 75 Old 02-10-2009, 04:27 AM
Raging Lunatic
choctaw's Avatar
Any ideas?
Can't help you with your issue, but thanks for the laugh.
Halito...Sa hohchifo ut Mike
On EARTH as it is in TEXAS
ΜΟΛΩΝ ΛΑΒΕ
"Fast Service Guaranteed...No Matter How Long It Takes"
choctaw is offline
post #4 of 75 Old 02-10-2009, 04:34 AM Thread Starter
symbols's Avatar
you two are worthless..........
Jason
symbols is offline
post #5 of 75 Old 02-10-2009, 04:34 AM
eric99f250's Avatar
how do you have it ran? are you getting the juice straight off of the battery or from the fuse box??? if its in the fuse box it might be shorting out or something...try running it to the battery and connect it to that and see if it still does it or not i have mine running off the battery and i havent had any problems at all
2000 F350 CC Dually--sold
looking for a new truck
eric99f250 is offline
post #6 of 75 Old 02-10-2009, 04:38 AM
CobbsDieselPerformance's Avatar
Thats a wierd issue, hope you get it resolved, where are you located at I have a friend way up in the Waste Management Company at they're corporate offices in Atlanta, GA.
CobbsDieselPerformance is offline
post #7 of 75 Old 02-10-2009, 04:40 AM Thread Starter
symbols's Avatar
I have a separate fuse box for all of my aftermarket stuff. I have one large wire from the battery providing power to all of the stuff on that fuse block. It doesn't blow any fuses and I just have to cycle the key and it restarts like nothing ever happened
Jason
symbols is offline
post #8 of 75 Old 02-10-2009, 04:42 AM Thread Starter
symbols's Avatar
Pasadena, TX. The office by me is in Pasadena also on Pansy St. If you wouldn't mind let him know what is going on and see if he can get them to stop doing it. The daycare is of Kenswick Dr. Thanks.
Jason
symbols is offline
post #9 of 75 Old 02-10-2009, 04:42 AM
eric99f250's Avatar
hmm well just try that take the wire for the juice from the compressor and hook it directly to the battery its gotta be shorting out somewhere
post #10 of 75 Old 02-10-2009, 04:57 AM Thread Starter
symbols's Avatar
It's not the compressor. The compressor comes on automatically and it's in the cab so I know when it's off or on. I've never had an issue while the compressor is running that I know of. Only when I push the horn button.
One thing I forgot to mention.... I use the same ground spot for all of my grounds so I tried moving it and it seemed to lesson the occurrence of the dying part but obviously the issue is still there.
It also doesn't die everytime. Sometimes it won't do anything and sometimes it will idle way down and almost die but still run.
Jason
symbols is offline
