Manual Trans. - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-09-2009, 07:42 PM Thread Starter
cmlrc's Avatar
Manual Trans.
O.K. so if this has been addressed before I can't find it... I have a late 99 with a 6-speed manual transmission. Can I add a performance chip like a superchip or hypertech and have it work with a manual trans? All the performance chips seem to effect the automatic trans. Any tech help?
"I've hunted most of the days of my life, the rest have just been wasted"
cmlrc is offline
post #2 of 3 Old 02-09-2009, 07:46 PM
Send a message via AIM to Fireman5606
They will all work with a manual trans, If you have the option go with a TW or Dp chip on it...much better than the two choices you mentioned, and comparable in price
"When everything is said and done, there will always be more said than done." - unknown
"whether you believe you can or you can't, you are exactly right" - Henry Ford ____________________________________________
Kelly
94.5 Ext cab, LB 250, 4X4, 5 speed, Bone Stock
Fireman5606 is offline
post #3 of 3 Old 03-16-2009, 07:27 AM
fallwater08's Avatar
Does anyone have any experience adding a chip to the 6.0 with the manual trans. I have a 2005 F350 that just seems to be lacking in power and torque with only 47K on the odometer. I've had my EGR checked and it was fine. The Ford tech said the 6.0 manuals just don't have the power like they should, but I was hoping a chip might help because I love shifting gears and don't want to buy a new truck.
fallwater08 is offline
