Weird Idea - Ford Powerstroke Diesel Forum
Old 02-09-2009, 03:49 PM
Send a message via MSN to JoeyCleland
Weird Idea
Has anybody ever had the idea of building a Diesel/Electric Powerstroke?
Much like a diesel electric locomotive, Large Alternator bolted directly to the back of the engine block, Large electric wheel motors mounted to a carriage that takes the place of the rear axle. I can think of a lot of benefits to this. Better mileage, Max torque at all rpms, No tranny or other driveline losses, and best of all Brutal HP numbers. I wonder what it would take to make this possible?
Joey
Old 02-09-2009, 03:53 PM
$$$$$$$$$$$$$$$$$$$$$$$$$$$$ and then some $$$$$$$$$$$$$$$$$$$$
Old 02-09-2009, 03:59 PM
and then some$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Old 02-09-2009, 04:02 PM
i know VW was designing a diesel hybrid that was going tog et around 90mpg.. not sure when its coming out though
Old 02-09-2009, 04:03 PM
Is it even worth it???
That is an interesting concept.
Another thing that could come into play, is that the alternators would not necesarily need engines as large as are currently installed in our trucks.
Think about the possibilities in weight savings... for example, swapping a 4bt Cummins in place of it's heavier 6bt brother, with no loss of performance.
Old 02-09-2009, 04:05 PM
Id be happy with the 60mpg that they are already getting
Old 02-09-2009, 04:06 PM
back to business
And then add thee extra weight of the drive motor(s) vs. standard drive train
Old 02-09-2009, 04:17 PM
Im evil though, i want to keep the Big boy 7.3 and install 2 MASSIVE motors. I imagine 1000whp wouldnt be too hard to do on a stock 7.3.
Joey
Old 02-09-2009, 04:21 PM
Plus the coolest part would be smokin the hell outa dodges with stock motor and not telling them about your Secret. Pop the hood and everything looks stock!
Joey
MONEY.....HAve you seen the price of copper these days? And guess what happens to be in an electric motor. Not to mention the extensive amount of fab work, licensing, DOT crap....I don't think it's worth the trouble. And with an alternator and motors of that size, you may be pushing your GVWR into CDL range.
