Keyless entry Help - Ford Powerstroke Diesel Forum
Old 02-07-2009, 06:54 PM
Keyless entry Help
I just bought my 1999 F250 Superduty 7.3L 2 weeks ago and I was wondering if it had keyless entry. I did the check where you turn the key from off to on eight times and the doors lock and unlock on the 5th time. So i ordered a key fob and when I try to program it, it wont work. I have a new battery and still nothing. Has anyone else had this problem. Is there a way to see if the sensor in the truck for the key fob is working or not. I checked and fuse under the hood for it but its the same fuse as the power door locks so that all works fine. Any help is appreciated thank you.
Old 02-07-2009, 07:49 PM
Lifetime Premium Member
did you order the fob from the dealer?if so,they should have been able to tell which one you needed.the fobs do have codes on them for certain yrs or something to that effect,I ran into this a couple yrs ago.
Old 02-07-2009, 07:58 PM
No i bought it off ebay and the FCCID on the remote is the same for my year.
Old 02-08-2009, 07:46 AM
Not to hijack, but I'm interested in this... can you give more info for the test? I have power locks, but what's this test about turning the key on and off 8 times? More details please... Remote would be nice to have, if I find out I have it as an option, I'd like to do that....
Old 02-08-2009, 08:01 AM
Send a message via MSN to pinkfloyd
subscibing interested also
Old 02-08-2009, 08:06 AM
If it aint a CAT itsa DOG
subscribing, i also would like to know if i have it.
Old 02-08-2009, 08:54 AM
The test is sit in your driver seat and unlock your doors wih the power lock. Then have your key in the ignition in the off position. Turn the key to the ON position then back OFF up to eight times simultaneously. Your locks with lock and unlock by them self's, that's how you know you have keyless entry option. Here is a website that has the programing instructions to almost every car, hope this help. Also just do a search on the forum and there are ton of threads about how to do this. Ford - Free Keyless Remote Fob Entry programming instructions, procedures for all automotive vehicles
Old 02-08-2009, 11:36 AM
Does anyone know where the Alarm module box is located so I can double check the numbers. I cant find anything online about where it is located it at.
