wiring diargram for throttle/pedal position sensor??? (only 3 wires) - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-07-2009, 08:52 AM Thread Starter
Hopefully simple Q.
My truck is "surging" at a constant pedal position. It isn't the CPS. I think it might be the pedal position sensor.
There are 3 wires going into it
brown/white
yellow/white
gray/white
does anyone have a schematic on which wires are what? I'm just going to put a voltmeter on the signal wire and go for a drive to see if it jumps around...
Keep your stick on the ice
wbones9 is offline
post #2 of 2 Old 02-07-2009, 01:34 PM
RadarRider's Avatar
Originally Posted by wbones9 View Post
Hopefully simple Q.
brown/white
yellow/white
gray/white
Can you scan for codes to make sure it's your TPS? You don't really wanna mess with something if you 'think' is the problem. Could possibly be a few other things. Usually, with a TPS, you'd have a problem like having your pedal halfway down & your rig starts respond as opposed to pushing it down less than 1/4 of the way & it responds.
"HEAVY" 2001 F-250 XLT 4x4 EC SB:
TW 6pos chip, S&B CAI, Monster 4" exhaust w/ Power Elbow, Big Head WGA, Technicooler, ITP boost fooler, Gen 1 Wicked Wheel, Six-Gun Tuner, Optima Yellow Tops, AutoMeter(Boost, Trans, EGT), CCV mod, MTS TC, MTS valve body, Trans Tech performance rebuild kit, TransGo shift kit, Hornblasters 242 Shocker Train Horns.
RadarRider is offline
