Abs light came on
hey guys,
i was driving from columbia to st. luois which is about 110 miles. and my truck drove fine the whole way until i came into st. louis and at the first stop light. as i was slowing i heard a very soft pop and then my abs light came on. now i didint notice any difference in braking or any lock up. so i was wondering what you guys think. thanks |
come on guys help please. i also now have a pretty good and i cant really tell where its coming from. im pretty sure it's not oil since it's clearer in color and its not red. any info would be helpful
Blew a brake line. Happened to me at a burger king parking lot. Your foot probably goes all the way to the floor before the truck stops. The fluid leaking should look like diesel fuel almost.
Trace the leak. I have an ABS light and no leaks, just stupid sensors somewhere. A leak would make it easy to solve your problem.
Keep the reservoir full to avoid bubblage. |
Check the front wheel bearings. when the bearing starts to fail it develops slop/play and the result is ABS sensor damage from contact with the sensor ring.
not sure what year you have but this applies to the 99-04 I know for sure. |
If all the major stuff checks out ok replace the sensor in the rear end, my light came on awhile ago, a guy i know that works on these things says thats the most common cause of a random BS light, the sensor was only $20 at the dealer but it was like 3 years ago.
