Oil spraying all over
I know it is the hpop o-rings. So how hard is it to replace them.
About a 5 min job. 6 if you do the back one.
Not hard at all. IF you cant get your hands on the quick disconnect tool, you can do it without disconnectiing them. You will use an open end wrench(dont remember the size). Which one is leaking? Are you gonna just go ahead and replace all three?
It is leaking at the fittings at the hpop there is two lines at the hpop.
Man bud you just can't catch a break this winter can you!!! It is much easier if you have the tool, but many make their own, if you Google HPOP O ring replacement you will surely find it. They never break down when it's 80 degrees outside!!
Good Luck!! |
So on my to repair list Front axle U-joints Hpop O-rings Belt Tensioner assembly Right side upper ball joint tie rod at Pitman arm Shocks all 4 I am sure there is more but that is what I know of right now. |
Well it is about 45 degrees out and I will be spending most of the day in my shop. Todays repair will be front axle u-joints.
Any one that wants to stop by and hang out just come on over. |
Damn. Lil too far away. Otherwise I would.
