Drive train issues (I think) - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-05-2009, 04:13 PM Thread Starter
petec83's Avatar
Im new here guys but have been reading on here for about 4 months now and just got the know how on how to ask for help and posting up pics and such. This forum has been very helpful to me and I thank everyone on here for it. I have a question. I recently got a 6" lift on my truck and I've been noticing a vibration off of take off and when Im going down the road at around 70. Not so much at 70 than when Im taking off. It was very bad when I first got it back so the guys at the shop installed the spacer you see on the pic. but I still have the problem just not as bad, its about 1" thick. Is it possible if I go with a bigger spacer it will help more? Is there a general rule of thumb how big the spacer has to be according to the lift? Thanks guys in advanced, keep up the good work.
http://i644.photobucket.com/albums/u...3/IMG_1250.jpg
2000 F350 CC SB 4x4
6" lift
36" 15.5 ATZ Micky T's
20" Niche Roxxy's
AFE Pro-Guard 7
5" MBRP Exhaust
Predator Tuner
Pyro, Boost, Trans Temp, Fuel Press. Gauges
petec83 is offline
post #2 of 5 Old 02-05-2009, 04:23 PM
Lifetime Premium Member
jbeasts10's Avatar
Have you checked your universal joints?Not sure about the spacer sizing.Does there seem to be alot of movement in the center support bearring ?
2001 F250.Custom Tuned,Ball-Buster Turbo,5"Exhaust
ITP Reg.Return,TD Billet Converter,Built Tranny,Snow Meth/Water Stage 2..plus a few more things!!She will Hunt
jbeasts10 is offline
post #3 of 5 Old 02-05-2009, 04:26 PM Thread Starter
petec83's Avatar
Not sure? How can I tell? I have been thinking about replacing the U joints. Should this be my starting point?
2000 F350 CC SB 4x4
6" lift
20" Niche Roxxy's
AFE Pro-Guard 7
5" MBRP Exhaust
Predator Tuner
petec83 is offline
post #4 of 5 Old 02-06-2009, 03:26 AM
Powerstroke Junkie
NCHornet's Avatar
That is the carrier bearing and I can't believe they would do a lift and not shim the carrier. Not a shop I would go to again and I would check the rest of the work they did!! If I remember it is 1/4" for every 1" of lift, but please Google "shimming carrier bearing" to be sure. This would be a 1 1/2" of a shim. I would take it to a 4x4 shop and have them check it out.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #5 of 5 Old 02-06-2009, 08:11 PM Thread Starter
petec83's Avatar
The funny part is a 4x4 shop did it and whats even better is that when I first got it back for getting the 6" lift it didnt even have any shim at all. It wasnt till I complained about it shaking very very bad on take off that they had me bring it back and put this in it. I dont know exactly what the size of it is but Im going to use it the 1/4" as a baseline. thanks buddy
2000 F350 CC SB 4x4
6" lift
20" Niche Roxxy's
AFE Pro-Guard 7
5" MBRP Exhaust
Predator Tuner
petec83 is offline
