battery cut off switch ...? - Ford Powerstroke Diesel Forum
Old 02-04-2009, 04:38 PM
anyone running any type of battery cut off? something to cut the power so nothing could drain the batteries...?? or start the truck
something like this...
or like this...??
or even something more simple.....??? show me yours
Old 02-04-2009, 07:12 PM
I use the 2 pole version of this switch for my drag car
Moroso 74101 - Moroso Battery Disconnect Switches - summitracing.com
In NHRA rules you can't use a solenoid because you are sposed to cut all the power off, and if you did that you wouldn't be able to turn it back on!
The problem with using a switch or a solenoid is the continous duty rating, to get one with a high enough rating for these trucks can get expensive.
Old 02-04-2009, 07:22 PM
i think it would be somekind of hassel to do this, just because we have 2 batteries
Old 02-04-2009, 07:30 PM
not really they are in parrallel, so you just switch on the load side of the passenger side battery.
Old 02-05-2009, 02:26 AM
Powerstroke Junkie
Why? You would loose all your presets on the radio!! If for long storage I would pull both batteries myself/
NCH
Old 02-05-2009, 04:34 AM
Send a message via MSN to justafarmtruck
have to reset the clock and presets every time and if you have elc. door locks you must not wana use them???
Old 02-05-2009, 08:05 AM
i dont loose my presets when i unhook batteries...but i didnt even think about keyless entry
Old 02-06-2009, 04:36 AM
just run them to a relay then to a switch from that and hide it well... or just make it so you cant get key power unless parking lights are on.... if you are trying to jack something your brain is going 100mph you wont get it to start.
