6 speed manual uses ATF fluid? - Ford Powerstroke Diesel Forum
Old 02-04-2009, 04:33 PM
Hi All,
I am new here, been lurking for a while. I just picked up a 2000 F-350 7.3 Diesel 4X4 Crew Cab with the 6 speed manual transmission. I was told this transmission and transfer case takes ATF fluid and not normal 80/90 weight gear oil like most manuals.
Is this correct or was I told a bunch of BS, this just does not seem right. I have had Toyotas and VW manuals and they all took normal gear oil in the tranny.
I want to put the best fluid in the transmission. What do you all recomend and how much do I need to get to do a complet change.
Thank you all very much for your time and help
Old 02-04-2009, 04:35 PM
It takes ATF.
Old 02-04-2009, 06:13 PM
Originally Posted by 2005F250 View Post
It takes ATF.
yup it takes regular ATF I changed mine when I put my new clutch in last summer
Old 02-04-2009, 09:00 PM
Its like 16qts of ATF, has something to do with the syncros in it. Actually all at least 95+ manual ford trucks use ATF.
Old 02-04-2009, 09:11 PM
dam thats weird i never knew that
Old 02-05-2009, 02:21 AM
Powerstroke Junkie
YEP ATF it is, Mercon V is fine to use in the manual and TC, I wouldn't put it in the 4R100 though. Good luck with your truck.
NCH
Old 02-07-2009, 05:43 PM
Thanks folks for all the help. I did the job today and it was very easy but messy. The 6 speed manual with the trans cooler takes just about 6 qts.
