4-Lo In Nuetral? - Ford Powerstroke Diesel Forum
Old 02-03-2009, 04:01 PM
The Screwy HEUI
Question 4-Lo In Nuetral?
I thought for a while, my 4-lo didn't work. I found today, it only engages in nuetral. Is it supposed to?
Old 02-03-2009, 04:04 PM
That is correct
Old 02-03-2009, 04:05 PM
I am pretty sure mine will go in in park also!
Old 02-03-2009, 04:09 PM
Never have tried it in Park. All the vehicles I have driven you had to be in Neutral to go in and out of 4Low
Old 02-03-2009, 04:12 PM
The Screwy HEUI
Mine won't do it in park. I tried for giggles today to see if it would work. When it's in park, 4-hi takes about a sec or so before the light comes on & 4-lo it doesn't do anything. In neutral, the 'Low Range' light comes on right away & you can hear/feel it engage.
Old 02-03-2009, 04:14 PM
And after you take it out of 4low, drive in reverse for about 10ft. This helps it disengage.
Chug-a-lug!!!
Only in "N". It won't work in "P".
Old 02-03-2009, 04:18 PM
The Screwy HEUI
Crap! I tried it in the driveway & after I turned the switch back to 4-hi, I just shut the truck off. Should I worry?
That settles it, then. "N" it is! Thanks, guys!
Old 02-03-2009, 04:20 PM
Chug-a-lug!!!
I wouldn't.
Old 02-03-2009, 04:21 PM
No dont worry. That just helps disengage it easier. If its still in 4low, you will be able to tell and you can just disengage it then
