braking - Ford Powerstroke Diesel Forum
Old 02-01-2009, 09:09 AM
braking
I thought this was odd, i checked my brakes today, and the rear brakes need changing again, i've had my 02 f-350 for two years now, and this is the second time i've had to change the rear brakes, i've never touched the front set yet, they are have a good 80-90% remaining. is this normal for the powerstrokes? because every car/truck i've ever owned has been the opposite, i'd go through the front brakes 2-3 times faster than the rears, could it also be an issue with the proportioning valve? also i wanted to upgrade the rotors and pads, any ideas where i could order from, i'm thinking ceramic pads this time, but i'll wait to hear what you guys have to say...............thanks
Old 02-01-2009, 10:51 AM
The Screwy HEUI
Have you had any issues resetting your rear calipers? You didn't use an airtool to reset them, right? There's a possibility you might need your rear calipers replaced if so. As far as pad/rotor upgrades, I've noticed many people go for cross-drilled rotors. When it comes to namebrands, I couldn't tell ya from experience, but EBC, Hawk, & Baer(little on the $$$$ side) are all great & make upgrades for your rig.
Old 02-01-2009, 12:21 PM
Powerstroke Junkie
Don't use drilled rotors unless they are the roto pros, others will crack. Powerslot and Cyro'd rotors are what I use and are awesome. But you have a serious problem!! You should go through 2-3 sets of fronts to one set of rears. My guess is you have rear caliper pin/pins that are stuck, or sticking. Make sure they are Free and properly lubed.
NCH
Old 02-01-2009, 01:53 PM
i replaced one of the calipers last year, i always grease my slide pins every brake change, so, i kind of ruled out that as the culprit, thats why i was starting to think the proportioning valve, if thats messed up, i guess it could explain, but then maybe its the front calipers, as the rear works just fine.......i've also seen adjustable proportioning valves, but for rear disk conversions, i was wanting to know if the stock unit can be adjusted at all? i'm not sure, i've nevered messed with this part before, though i've done tons a brake work..........................thanks.............. .....any opinions on ceramic pads?
Old 02-01-2009, 02:07 PM
The Screwy HEUI
They say ceramic pads are the way to go, though a bit more on the expensive side. They only problem I've ever had with them is excessive squeaking if an anti-squeal pad or brake grease isn't applied in the correct areas on the pad(back & ears.).
Old 02-02-2009, 02:09 AM
Powerstroke Junkie
If you rear brakes are wearing that fast ceramic pads ain't going to help, they may last longer, but you still have a problem. If you are sure there is no problem with the rear calipers, I would replace the proportioning valve, not sure what else could cause it.
NCH
Old 02-02-2009, 05:46 AM
i was thinking about all night, i came up with either the front slide pins are stuck, because i've never serviced them, or i might have air in the front lines, i'm going to tear into it here in a couple of days, i'll find out whats wrong, just wanted to see if anyone has come across this before.........thanks ........btw, i'm replacing all rotors and brakes too...
