No WTS Light. Most likely causes? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-02-2014, 01:47 PM Thread Starter
Wolfesscythe's Avatar
So today, I got in my truck, turned the key, no WTS light. The truck runs and operates perfectly.
Nothing seems to change other than the fact that the light no longer illuminates. What should I check first? Is it most likely a bulb?
2001 6-Speed F250 SCLB - South Bend SFDD250-6 Dual Disc Clutch - 7.3 with DIY 6637 - Diamond Eye Turbo-back 4 inch straight - TS 6-Pos PHP Tunes - Billet X-Wheel - Foil Delete | 1988 5-Speed F250 SCLB - 7.3 IDI - Stock
Wolfesscythe is offline
post #2 of 9 Old 08-02-2014, 02:39 PM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
Yea. I would think so...
Either that or some connection to it. Possibly could the PCM have a problem? I mean, when "stone cold" in the morning, I would verify the Glow Plugs were coming on despite the lack of a light (before Winter gets here!)
NoRalPh is offline
post #3 of 9 Old 08-02-2014, 03:07 PM
hansel's Avatar
Quoted: 94 Post(s)
Well if it is the bulb, it's not that hard too change. I just took my dash apart because the area around the tac and speedo was dark driving me crazy, the only thing was I bought the tool to remove the stereo because there are 2 screw's that hold the dash cover in place. After getting that out of the way it's 4 bolt's that holds the dash cluster in place, then there is 3 harnesses that plug into the back, and the tricky part is unclipping the gear shift indicator. But all the bulbs just plug into the back and they are all marked for the location so you know exactly which one is which.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #4 of 9 Old 08-02-2014, 05:47 PM Thread Starter
Checked all my fuses, they're fine. Checked the GPR, it's operating correctly. It has to be a bulb, or a wire going to it. I'll go to the Auto parts store tomorrow and buy some of those stereo removal tools and may as well buy a bulb while I'm at it.
post #5 of 9 Old 08-03-2014, 12:21 PM Thread Starter
And the WTS light just started working again, out of nowhere. Odd. Guess I won't worry about it.
post #6 of 9 Old 08-03-2014, 01:19 PM
Quoted: 134 Post(s)
'Till it goes away again....
Sounds like nothing to really worry about, it's not giving you any valuable information anyway. The WTS is just a timer and no indication of much at all.
NoRalPh is offline
post #7 of 9 Old 12-19-2015, 05:31 PM
natemoses13's Avatar
My WTS light is not working either - it never has since I bought it back in May - but now that it is cold, it is obvious that there is something wrong since it took me 20 minutes to start the truck in 35 degree weather. I'll check the bulb and run the gpr test, but I have to get to the bottom of the problem. The dash lights on my late 99 are in slightly different places than the early 99?? I can't see where the wait to start light should be......
E99 F350 crew cab dually flatbed. 2wd 6-speed. Boost and egt gauges. 6637 intake. Superchips flashpaq.
L99 F350 crew cab dually flatbed. 2wd Auto. Billet TC & aux cooler. 6637 intake. Superchips flashpaq.
natemoses13 is offline
post #8 of 9 Old 12-19-2015, 08:07 PM
Quoted: 2 Post(s)
I have a cluster illumination bulb that does the same thing...Has a mind of it's own LOL...Usually doesn't come on right away but once I'm driving it comes to life.
Licensed Truck Mechanic
1999 F250 CC 4x4
7.3L/4R100, 3.73LS
290,000 miles
87 Mustang S/Pro drag car
600HP 472" BBF/C6
CashMonkey is offline
post #9 of 9 Old 12-19-2015, 11:07 PM
five0merc's Avatar
Quoted: 96 Post(s)
The bulb might be barely in so it shakes in and out of contact?? Just thinking out loud
1965 Mercury Comet Caliente
2002 F-150 Lightning True Blue #4516 of 4726 (1130 TB) Totaled by dodge driver
2003 F-250 CCSB XLT Lariat 4x4 Oxford White 7.3
five0merc is online now
