7.3 Prefered - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-26-2006, 03:07 PM Thread Starter
7.3 Prefered
I made a short trip today in my dads 06' PSD with a power pup downloader everything else stock. It was just under 400 mile trip, pulling 8K trailer. To tell the truth I was rather dissapointed in the truck. The truck could not maintain 70mph on the interstate without unlocking the T/C or downshifting to 4th. I did like the tow/hual mode. That thing is guarateed to stop you in a hurry. It works just like a Trans Retarder. I just wish my 01' had that option. I have towed the exact same load a hundred times with my 01' and I can set the cruise at what ever speed I prefer that day. It has no trouble pulling that load or heavier ones. My 01' will almost never unlock or downshift, unless it is some kind of rediculously steep grade. Also the fuel milage with the 6.0 is terrible compared to my 7.3. I think we average like 12.5, heck I can get 14-15 depends on how big of hurray I am in. Of course I had to rub it in even thou the 6.0 may out run the 7.3 from a stop, it just doesn't have that low end grunt to keep things rolling.
01' F250 7.3, AFE PG7 Stage II, GTP38R, Hi-Flow outlet, Non EBPV Pedistal, DI Up-pipes, DI- Regulated return, BTS Dual HPOP, 4in Silverline, DP Tuner F5, ITP Annilator, BTS Trans, 6.0 Trans Cooler, Detriot Tru-Trac 3.73, Powerslot's Cryo w/Hawk LTS, Rotella ELC, Nitto Terra Grappler 285/75/16
SuperDuty1 is offline
post #2 of 8 Old 12-27-2006, 02:56 PM
International Threat
Marty's Avatar
Just curious, how many miles does that 6.0 have on it?
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #3 of 8 Old 12-27-2006, 03:33 PM Thread Starter
29,000 miles.
post #4 of 8 Old 12-27-2006, 05:33 PM
99 7.3's Avatar
superduty1. i have a question for u. i know that it is off topic, but how did you rig up ur 6.0 trans cooler. i have one and need some ideas on how to run the stock 3/8 tanny lines to the new 1/2 tranny cooler lines from the 6.0. oh ya did u have to fab any new pieces to mount the new cooler one to ur truck?
99 7.3 is offline
post #5 of 8 Old 12-27-2006, 08:20 PM Thread Starter
I just went to local Fastenal store. I got 2 brass 90 degree female I think 3/8in. thread fittings. 2 3/8in. barbed and 2 1/2in. barbed with 3/8in. thread. I can't remeber every detail. You will need 1ft of 1/2in hose and I used 7ft 3/8in hose. I think from the bottom of the cooler to the end of your new fitting should be 3 or 3 1/2in. Whole bunch of hose clamps. I double hose clamped every fitting, that is up to you. When you put your fittings on the cooler, you will need both of the 3/8 ends facing the passenger side. I then used what was left of the old and new hose, split it and wrapped around the lines anywhere they touched frame, radiator ect. to keep from premature failure. I also stil use the oil/water cooler in the radiator. You will have to modify the top mounts on 6.0 cooler or your bolts will not line up. If you look at your old cooler you will see how much shorter the mounts are compared to the 6.0. The 6.0 has a much broader design and will not let it sit down in the slots. It was definatly worth the effort, since I changed it I can't get my temp. above 140 and that was 100degree outside pulling 16K.
post #6 of 8 Old 12-27-2006, 09:18 PM
Marty's Avatar
Originally Posted by SuperDuty1 View Post
29,000 miles.
That 6.0's not quite broken in yet
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
post #7 of 8 Old 12-27-2006, 09:39 PM
99 7.3's Avatar
tranny cooler
thanks for the info!!!
99 7.3 is offline
post #8 of 8 Old 12-27-2006, 09:42 PM
WD40's Avatar
Quoted: 35 Post(s)
Sounds bad to me. My truck is mostly stock and I don't think it would pull down with a small load like that. You shouldn't be able to tell 6000 LB. is back there. MPG is about right for a truck with only 29000 on it.
2006 Ford F-350 Crew Cab Lariat 4X2 PSD 6.0 TorqShift Automatic Transmission. Upfitter Switchers Chrome Door Handles,
Oxford White with lower part being Arizona Beige Metallic.
Creative Coating Sprayed in bed liner.
20K Reese 5th wheel hitch.
Mods. 4in. Silverline stainless steel exhaust
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
Is it time to go camping?
EX-USN
Doug
WD40 is offline
