trans temp guage sender
on a 7.3 where do you put the trans temp sender at the guages are auto meter thanks for the help
Didn't it come with instructions?
there is a service port on the drivers side, just above the pan. or drill tap the pan. Id rather have it in the pan personally.
i have looked all over the side (driver side) and there is no port to put the sender. i really dont want to drill a hole in my pan. what else can i do. i looked at the other post on this trans temp sender location and looked on my pan and im still lost please help
I don't know how reliable it would be but if you have a way to make your own cooler lines you cooled to into the pressure side of the cooler line?
mud-nut that help out alot , i found it thanks
That helps a ton
There is little difference between pan temps and pressure port installation, I use the pressure port, why drill a hole in a perfectly good pan. Make sure the end of the probe doesn't come in contact with the casting inside the trans, you may have to use some washers to space it out a bit.
NCH |
A friend of mine put is sending unit in the drain plug hole in his after market pan!
