ZF6 Drag Racing? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 19 Old 07-31-2014, 10:30 PM Thread Starter
Wolfesscythe's Avatar
Quoted: 2 Post(s)
ZF6 Drag Racing?
Went to the Carolina Diesel Nationals last Saturday, and I don't think I seen a single straight drive run the track.
I know that technically, an automatic will out run a manual every time, when dealing with these trucks, considering shift time and turbo spoil and such. My question is this.
If you own a ZF6 and have ever drag raced, rather it be on a track, or just wanted to out run your friends, what do you typically do?
What gear do you launch in? Around about what RPM do you launch said gear from? Are you popping the clutch?
Not that I intend to race my truck, just following the G.I. Joe code. The more you know.
2001 6-Speed F250 SCLB - South Bend SFDD250-6 Dual Disc Clutch - 7.3 with DIY 6637 - Diamond Eye Turbo-back 4 inch straight - TS 6-Pos PHP Tunes - Billet X-Wheel - Foil Delete | 1988 5-Speed F250 SCLB - 7.3 IDI - Stock
Wolfesscythe is offline
post #2 of 19 Old 08-01-2014, 03:34 AM
I will have to talk to a buddy I work with, he seemed to be pretty good at speed shifting his zf6. I have been driving standards all my life, but this one is gonna take me awhile I believe.
Early 99' F350 4x4 Dually Lariat
7.3 6 speed, PHP Hydra, Diamond Eye 5" SS straight pipe, RiffRaff 6637 intake, Isspro ev2, leveling kit
Bjesse is offline
post #3 of 19 Old 08-01-2014, 04:46 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
You would have to double clutch it either way to speed shift, but it's a truck transmission, it won't be fast then compared to a sports car, but if drag racing in a zf6 is what you want then shift at very high rpm's and start in 2nd gear
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 19 Old 08-01-2014, 05:11 AM
sbluke55's Avatar
Quoted: 553 Post(s)
Garage
It depends on gearing and tire size. I can start in second but it lugs bad. I have 35" and 3.73 gears. I can get a quick start when I start in first and launch at 2300-2400 and slip the clutch pretty good.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #5 of 19 Old 08-01-2014, 06:07 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I've only driven standards with 4.10's, first gear just don't have enough room, I start in second unless I'm loaded HEAVY, on a track tho it will get you a jump, but your gonna have to shift at about 20 feet
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 19 Old 08-01-2014, 06:36 AM
Quoted: 2 Post(s)
I drive my Mustang instead.
I don't think I've ever considered running this truck on a track or even against anything from a drag perspective. Not that I wouldn't, I just don't think it would do all that well.
01 F350 Dually 4x2 Long 7.3 - Manual - Mods: Hutch, Harpoon, Remote Fuel Filter, Southbend Clutch, Heim Joint, Gauges, Disabler, 08 Tail w/Camera, Pioneer Head w/Lockpick, Exhaust Brake, Rails, Air Raid, 06 Headlights, 50 cent. Coming next: Exhaust. Wish list: Train horn, 4x4 conversion, Exhaust, Turbo, Chip.
06 Mustang GT - GCC spec (Infidels May be closer than they appear)
16 Sonata Hybrid - Gas saver
Arizona_SVO is offline
post #7 of 19 Old 08-01-2014, 06:39 AM
Real Men of Genius
Super Diesel's Avatar
Quoted: 10 Post(s)
Feedback Score: 9 reviews
I'll let you know how it goes soon
Arizona_SVO likes this.
Chris | 2005 F-250 RCSB | "Ranger - Turbo Diesel V8"
CED Compounds - Conventionals - Supporting Mods
Super Diesel is offline
post #8 of 19 Old 08-01-2014, 06:56 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I forgot about you having a hand shaker chris
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 19 Old 08-01-2014, 08:49 AM
Real Men of Genius
Quoted: 10 Post(s)
Yep. ZF6 with a short throw shift kit.
post #10 of 19 Old 08-01-2014, 01:02 PM
From MidWest? How do u like it? I want to install one when I re build it all
E99 F250 XLT SuperCab 4x4 3.73 gears, 213k and climbing, ZF6 trans w/ 1944-60K SB Clutch/Flywheel, 6637 filter, muffler/cat delete w/ 5 inch tip, PHP Hydra, 4 gauge pod(EGT, EOT, FUEL PSI, BOOST), 12000 lb Warn Winch, 07 headlights/grill, 6k HID kit, Bushwhacker pocket style fender flares, Pioneer 7" touchscreen, 2.5 inch leveling kit with 315/75/16 General AT2s on stock 16 bullets, HPX
Next up: Rebuild Kit and Billet Wheel, Fixing E-brake so I can park on hills!
Tow51Stang is offline
