Fuel Mileage?????? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 33 Old 07-31-2014, 07:45 PM Thread Starter
hansel's Avatar
Quoted: 97 Post(s)
Fuel Mileage??????
Okay, I know another fuel mileage issue
I picked up a 2001 with 224K, so far I've changed all the fluids and filter's, and have been running Diesel Kleen and 2 stroke oil on every fill up.
I've also cleaned the EBPV tube and sensor, replaced the leaky ICP.
The truck is a CCSRW 4X4 with no lift, running a 285/75R16 tire. I've put almost 2K on the truck and it seems like the better it is running,but the mileage is dropping off, I'm getting in the high 13mpg range but when I first got her she was getting around 14.5-15.1mpg (hand calculated) I plan on having the tank filters cleaned but on my 2000 truck it didn't help with the mileage but it did help wake her up.
Any idea's????
Almost forgot, not a puff of smoke at start up or when driving, even under hard acceleration
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #2 of 33 Old 07-31-2014, 07:53 PM
Rodslinger's B1TCH
how is your atf looking?
steve604 is offline
post #3 of 33 Old 07-31-2014, 08:09 PM Thread Starter
hansel's Avatar
Quoted: 97 Post(s)
It is brand new now, but was questionable when I changed it
It doesn't feel like it's slipping, the truck is running much better than when I bought it, just seems the better it's running the worse the mileage has gotten, and I can't afford too start changing allot of stuff.
Would a stock exhaust be my problem??? I have a Airaid intake on it, but the exhaust is all stock.
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
post #4 of 33 Old 07-31-2014, 10:38 PM
Wolfesscythe's Avatar
Quoted: 2 Post(s)
Tuner, intake and exhaust bumped me up from 16mpg to 21-22 on the highway, same year truck. I also seem to feel like DieselKleen has always given me worse fuel mileage, so I stopped using it regularly.
2001 6-Speed F250 SCLB - South Bend SFDD250-6 Dual Disc Clutch - 7.3 with DIY 6637 - Diamond Eye Turbo-back 4 inch straight - TS 6-Pos PHP Tunes - Billet X-Wheel - Foil Delete | 1988 5-Speed F250 SCLB - 7.3 IDI - Stock
Wolfesscythe is offline
post #5 of 33 Old 08-01-2014, 12:36 AM
Rodslinger's B1TCH
good point, maybe try running without additives for a couple of tanks.
the fuel systems in our trucks don't really need much attention. according to what i've read from injector rebuilders, the fuel side of the injectors seem to last for ever, it's the oil side of them that sucks.
steve604 is offline
post #6 of 33 Old 08-01-2014, 05:52 AM Thread Starter
hansel's Avatar
Quoted: 97 Post(s)
Okay, I will leave out the diesel kleen and see what happens, I will keep up on the 2 stroke for some lubrication, my old truck and this seem too love 2 stroke oil
The reason for adding the DK was the PO probably did nothing for fuel additive
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
post #7 of 33 Old 08-01-2014, 05:57 AM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
ulsd is rough on the o-rings...other than adding something every once in a great while I dont touch it. And on any turbo something (car or truck) more free flowing is always better...
oh and atf that is old is usually stiff and so when you changed it (better for the truck) the trans "slips" more like it is designed.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #8 of 33 Old 08-01-2014, 07:16 AM
Jerrybizzle's Avatar
Quoted: 23 Post(s)
Still on original injectors?
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
post #9 of 33 Old 08-01-2014, 08:15 AM
blue99stroker's Avatar
Quoted: 258 Post(s)
you could cut the muffler off and see if it helps at all. thats free after all
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #10 of 33 Old 08-01-2014, 06:04 PM Thread Starter
hansel's Avatar
Quoted: 97 Post(s)
Ya, still the original injector's but I knew when I bought it they might need some attention. I didn't think that the same day I bought it my son would total his truck, and then have too replace my daughters car
So I need to nurse them for awhile
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
