Rotella T Oil milage - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By BryceB
post #1 of 7 Old 07-31-2014, 03:23 PM Thread Starter
Quoted: 2 Post(s)
Stupid me... I thought the whole T line of Rotella was synthetic, but nope. Bought the 15w40 dino oil instead.
Should I do this next oil change at 3,000 or could I go further and be safe?
winona78 is offline
post #2 of 7 Old 07-31-2014, 03:41 PM
BryceB's Avatar
I have done 5,000 mile changes on my truck. Currently it is at 211,000 miles with no oil related issues. Oil Analysis by Blackstone Labs always tells me the oil was in good shape and capible of going longer.
7point3 noob likes this.
2001 Ford F-250 SD CCSB 7.3 PSD - AIS Intake, Zoodad,
MBRP 4" XP Series Exhaust w/ Muffler, HD4R100, 26 row Trans Cooler, Fumoto Valve,
285/75R16E BFG AT KO, Pioneer AVIC-Z130BT Nav, BOYO VLT-422C Back Up Camera,
Scangauge II, Glowshift 3 Gauge Pod (EGT,TFT,Boost), PHP FU Chip, Huskyliners, Huskyliner Mud Flaps, Warn Premium Hubs, Riffraff Boots/Clamps/inserts
Dyno'd at Mo's Speed Shop 11/3/12 - 307rwhp / 651rw ft-lbs <<<--- On PHP 120Race tune
BryceB is offline
The Following 2 Users Say Thank You to BryceB For This Useful Post:
7point3 noob (07-31-2014), winona78 (07-31-2014)
post #3 of 7 Old 07-31-2014, 03:45 PM Thread Starter
Quoted: 2 Post(s)
Fantastic to know... non synthetic oil for the 5,000 miles?
winona78 is offline
post #4 of 7 Old 07-31-2014, 04:27 PM
BryceB's Avatar
Yep. Other than whatever Ford put in it at the factory, it's only had Rotella-T 15w40 Regular oil and Motorcraft FL1995 filters.
BryceB is offline
post #5 of 7 Old 08-01-2014, 02:05 PM
Delo400 dino oil on my truck since day 1 every 5k miles with motorcraft filters and Blackstone always tells me it has enough life in it for another 2500 miles but I like to be safe either way.
E99 F250 XLT SuperCab 4x4 3.73 gears, 213k and climbing, ZF6 trans w/ 1944-60K SB Clutch/Flywheel, 6637 filter, muffler/cat delete w/ 5 inch tip, PHP Hydra, 4 gauge pod(EGT, EOT, FUEL PSI, BOOST), 12000 lb Warn Winch, 07 headlights/grill, 6k HID kit, Bushwhacker pocket style fender flares, Pioneer 7" touchscreen, 2.5 inch leveling kit with 315/75/16 General AT2s on stock 16 bullets, HPX
Next up: Rebuild Kit and Billet Wheel, Fixing E-brake so I can park on hills!
Tow51Stang is offline
post #6 of 7 Old 08-01-2014, 05:59 PM
Quoted: 17 Post(s)
Lol when I bought my excursion my friend told me he put Synthetic Rotella 15w-30 & changed it every 10k. When I went to change the oil I found out they (Shell Rotella) do not make synthetic 15w-30. They make 5w-30 in synthetic, which I went with even though I'm in a warm climate.
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #7 of 7 Old 08-01-2014, 07:37 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I use rotella t, love it, actually starts with speed and like it was just cut off a few minutes ago (I'm sure the NEW batts helped when I performed that oil change too)
But I got no complaints on it, every 4-7k (depends on how tight my funds are)
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
