howl in front end - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-31-2014, 02:04 PM Thread Starter
jmaroon's Avatar
howl in front end
so i've got this "howl" on the drivers side of my front end.. it happens at 45 mph and above.. most of the time.. i've changed in the past six months.. calipers, ball joints, and hub bearings.. took it in for an alignment, they changed my caster shims.. when i drove it away from the alignment shop, this howl started.. I've dissassebled the dang thing twice trying to figure out what it is, but i'll be danged if i can find it.. i changed the calipers and pads, and even warrantied out the drivers side hub, even though i knew this sound was too high pitched to be a failed bearing.. dust sheilds aren't dragging, and it does it intermittently.. at varying speeds.. i know i need shock bushings but i find it hard to beleive that is the cause of this.. i'm stumped..
it sounds like .. waaaa wa waaa waa wa waaaa waaa .. lol.
any ideas
e99 F250 7.3 4x4 sb
33" dick cepeks
diy filter - done
gutted ebpv
straight pipe - DONE! .. WOW!!!
later model pcm - soon to be done
guages - next on santy clause list
chip - later on down the road
others in the fleet:
76 IH scoutII
74 IH scoutII
2 73s for parts
93 ranger commuter/beater truck
jmaroon is offline
post #2 of 2 Old 08-07-2014, 03:03 PM Thread Starter
jmaroon's Avatar
k.. so i THINK i found my issue.. took my warn manual hubs out and the snap ring on the back side that holds the center peice into the outer spline part was .. no longer present.. soo anybody know where i could buy that? just the snap ring?
e99 F250 7.3 4x4 sb
33" dick cepeks
diy filter - done
gutted ebpv
76 IH scoutII
74 IH scoutII
2 73s for parts
jmaroon is offline
