ECM code DPC-422 is this the only tuner chip I can use ? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-29-2014, 07:57 PM Thread Starter
My truck 00 f350 SD CC 4x4 DRW auto has a ECM / PCM code on it that reads DPC-422 and I was looking at getting a used tuner/chip from a friend but his code is VDH 02 auto 7.3 will this work or do I need a chip from the same ECM as mine ?
Thanks
Chevydog is offline
post #2 of 7 Old 07-30-2014, 01:03 AM
blue99stroker's Avatar
Quoted: 289 Post(s)
it should work.
dpc-422 isnt your code btw.
it should be 3 letters 1 number.
since its a 2000 it should be pmt1
blue99stroker is offline
post #3 of 7 Old 07-30-2014, 03:11 AM
SeeYa's Avatar
Thanks
It will not work. The VDH DPC-462 PCM is for a 2002-2003 Federal truck. The DPC-422 is for a late 1999-2001 federal PCM. The chip will need to be reflashed for the 2000.
~Diane
Custom Tuning-Computer Chips
Flash Programmers-Aftermarket parts
Ford Power Stroke Engine and Transmission Tuning Specialist since 2004.
828-221-0076
SeeYa is offline
The Following User Says Thank You to SeeYa For This Useful Post:
Dave (07-30-2014)
post #4 of 7 Old 07-30-2014, 06:03 AM Thread Starter
OK so I looked at the ECM again and it has NVK4 on the top..........am I still SOL or can the chip work with my truck ?
If it wont work what would it cost to get it burned for my truck ??
Thanks
Chevydog is offline
post #5 of 7 Old 07-30-2014, 09:01 AM
Quoted: 902 Post(s)
Feedback Score: 3 reviews
It will work
Corey@CNCFAB is offline
post #6 of 7 Old 07-30-2014, 09:24 AM Thread Starter
OK great sounds like it will work with my ECM my question is it has default ECM on the tag VDH4 it is a 6 pos TS style chip with a stock setting and then 5 other settings. will the stock setting be the same as my ECM NVK4 or will I have problems ?
Thanks for all the info.
Chevydog is offline
post #7 of 7 Old 07-30-2014, 12:20 PM
SeeYa's Avatar
Thanks
No NVK is still a DPC-422 not a DPC-462 (VDH).
If you use the one from the VDH truck you will not have a tach, the water in fuel bowl light will stay on and the trans tuning will be different.
Get it reburned and it will work properly.
~Diane
828-221-0076
SeeYa is offline
