Dieselsite Coolant Filtration Kit Question. - Ford Powerstroke Diesel Forum
post #1 of 15 Old 07-29-2014, 10:26 AM Thread Starter
Msp079's Avatar
Quoted: 52 Post(s)
Question Dieselsite Coolant Filtration Kit Question.
Hi All,
I am looking for 2 inline shut off valves that I can put into the hose to make it easier when I remove the dirty one to put in a fresh one.
Has anyone done that and could you direct me on a part nuber or link that will work.
Thanks All
2005 F350 Harley Davidson Edition CCSB SOLD!!!
Icon Vehicle Dynamics 4.5" stage 4 lift, 37x13.5R20 Toyo Open Country M/T, 20x10 Fuel Throttle wheels, ARP headstuds, EGR delete, MBRP 5" powdercoated turbo back exhaust, wicked wheel, Blue spring mod, Mishimoto Radiator, oil cooler, stand tubes and dummy plugs, Sinister Diesel coolant filter, 6.4 banjo, Air Raid air filter, SCT X4 tuner with tunes from Innovative Diesel, EGT, HPOP, fuel pressure A-pillar gauge pod
Msp079 is offline
post #2 of 15 Old 07-29-2014, 10:54 AM
E-Man's Avatar
Quoted: 5 Post(s)
You can get them right from the Dieselsite website when you place your order. $17.96 for the pair. I have them on my system.
2001 F-250 CC SB 4x4 Off-Road w/ 88k miles on the 7.3. 4" lift on 35" BFGs. All synthetic fluids (Amsoil & Schaeffer's)
S&B intake, 4" turbo-back straight-pipe, 6.0 trans cooler, Dieselsite coolant filter w/ Delo ELC, Isspro gauges, Mag Hy-Tec diff cover
2012 tailgate, rear bumper, and tailights
2001 Excursion Limited
Only 55k miles on the 7.3
Bone stock
E-Man is offline
post #3 of 15 Old 07-29-2014, 05:30 PM Thread Starter
Msp079's Avatar
Quoted: 52 Post(s)
I just looked and found them on dieselsite.....Unfortunately I ordered everything on Monday and it's coming on thursday...so I wanted to do it all friday I should be able to find something at a plumbing shop that could so the same trick assuming right?
Msp079 is offline
post #4 of 15 Old 07-29-2014, 05:59 PM
Christ Follower
7.3Excursion4x4's Avatar
Quoted: 14 Post(s)
Go to your local hardware store. Show them a picture of the one you want and they should have one.
410,000 miles
PHP Hydra Mishimoto Radiator
Stage 1 Full Force Injectors
MBRP 4" Turbo Back
F-650 Dash w/EV2 Gauges
CT Performance Suspension
Firestone Ride Rite
DieselSite 4R100, Adrenaline HPOP, WW2
DieselSite Engine & Intercooler Boot Kit
DieselSite Tranny & Coolant Filters
SSBC V8 kit with EBC Rotors
NCHornet's CCV, Swamps IDM
Derale Atomic Cool
6.0 Trans Cooler, Cat ELC Coolant
Mag Hytec tranny pan
7.3Excursion4x4 is offline
post #5 of 15 Old 07-30-2014, 05:53 AM
Jennifer@Dieselsite's Avatar
Quoted: 6 Post(s)
We use chrome and they are 3/8ths ball valves that you should be able to get anywhere.
3/8ths pipe thread x 3/8ths NPT.
Good luck!
Jennifer@Dieselsite is offline
post #6 of 15 Old 07-30-2014, 06:47 AM
hansel's Avatar
Quoted: 100 Post(s)
I didn't have the valve's on mine and I didn't loose that much coolant when changing out the filter. But the local hardware store should have them
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #7 of 15 Old 07-30-2014, 02:08 PM
JSchuricht's Avatar
I have an old Dieselsite kit, if the current one is still mounting above the radiator then you are above the fill line so the bulk of the loss is from what is already in the filter.
JSchuricht is offline
post #8 of 15 Old 07-31-2014, 11:46 PM Thread Starter
Msp079's Avatar
Quoted: 52 Post(s)
Thanks guys for the tips...
Question. ..I have been having a awful time getting the plug out of the side of the thermostat housing....It's takes a square bit....What have you guys been using to get it out???
I went to harbor freight couldn't find anything...advanced auto had nothing...advanced auto had nothing ...not even Lowes when I called.......Any help is appreciated cause I'm at a stand still with flushing my radiator out.
Msp079 is offline
post #9 of 15 Old 08-01-2014, 12:09 AM
JSchuricht's Avatar
I used a ground down carriage head bolt and a few nuts wedged together.
post #10 of 15 Old 08-01-2014, 04:14 AM
Christ Follower
Quoted: 14 Post(s)
iirc, its just the 1/4 or 3/8 end on a ratchet
410,000 miles
MBRP 4" Turbo Back
Firestone Ride Rite
Derale Atomic Cool
