hit 21 psi with no chip - Ford Powerstroke Diesel Forum
Old 12-25-2006, 07:01 PM
I dissconected the wastgate on my 01 today and i gained 5psi, 16 to 21 now. I was suprised because when i did it to my 99.5 i only saw a 2 psi improvement. I dont have a chip yet as jody is takeing the rest of the year off but i cant wate to get his tune. I going to have to order a boost fooler now. and my only mods are afe stage 2 pg 7, 4" trubo back stright pipe, and zoo dad, all my gauges. just though i would share.
Old 12-26-2006, 12:35 PM
i have a 99 and i just put some guages in today and it was about 18 or 19 then i disconnected it and got right under 25 but im not sure if the engine is defueling or not
Old 12-26-2006, 04:17 PM
Wow..Thats good for not having an chip...With my chip on the 100hp setting I can get up to 30lbs of boost..You got me wondering if I unplug what the outcome would be.
Old 12-26-2006, 06:52 PM
With the mods I have on my rig, I have hit 26 PSI with wastegate disconected, but I feel like the enigne did defuel when I did it.
Old 12-27-2006, 12:36 PM
Send a message via ICQ to Lord Tauk Send a message via AIM to Lord Tauk
When you guys disconnect the wastegate, you're just pulling off the rubber pressure connector with the hose (red I think?) right?
Another question, what's a safe boost limit for the stock thrust bearing turbo? Keep it under 30 PSI with occasionally running it up a little higher when racing, hot rodding, etc. etc.? I know it all depends on the tune, but if you guys can hit 30PSI with a 100HP setting from a tune, then you disconnect the wastegate...
Old 12-27-2006, 03:43 PM
Just Simply pull off that redline running to the wastegate, I then stuck mine on the the bolt sticking past the nut on my intercooler pipe clamp, that way it can still pull vacum.
