TC Mod - New Twist - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 11 Old 07-29-2014, 07:56 AM Thread Starter
TC Mod - New Twist
OK, I'm looking to use the TC Mod to enable an electric fan on the AC condenser. I'm looking for a way to energize an electric pusher fan relay when the AC compressor clutch is engaged AND the torque converter is NOT locked up. That way when the truck is at speed, the fan will turn off. The AC cools fine when the truck is going down the road, it is just in stop and go traffic that it get a little warm (AC temperature, not engine temperature, the engine never gets too warm). Is there a wire that is energized when the TC is locked? I know the purple/yellow is the ground, but I'm having trouble getting my hands around a control circuit to stop the fan when the TC is locked up. Any help?
2002 F250 Harley Clone CCSB
AIS Intake
4"turbo back with FET resonator
DI Tune
AC Single Shot Injectors
38R Turbo
Recon LED Tailights
Recon 3rd Brake Light
55 Watt Halogen backup lights
2008 tailgate
Backup Camera
2005 Grill
2005 Headlights
Coolant Filter
Spin on Transmission Filter
Fiberglass Toneau Cover
Bedrug
LED Bed Lighting
bubba57-chevy is offline
post #2 of 11 Old 07-29-2014, 08:34 AM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
But, if that Ground is to the Lock-Up alone (and I don't know that it is...) then that's all you need. Just have that ground (again, if usable) complete the coil circuit in a relay, thus "opening" the relays NC contacts, and stopping power from flowing to the fan.....
BUT, I'm not sure why this should be necessary in the first place. If your AC starts blowing Warm when not at HiWay speeds, something wrong ;(
NoRalPh is offline
post #3 of 11 Old 07-29-2014, 09:38 AM Thread Starter
Thanks NoRalPH. It's not that it blows warm, it just doesn't blow as cold as it does going down the road. I've installed AC units on multiple street rods with dedicated electic fans blowing on the condenser and it does make a difference at low speeds. I guess I was thinking it might help with the truck also.
post #4 of 11 Old 07-29-2014, 10:28 AM Thread Starter
I'm thinking something like this might work.
AIS Intake
DI Tune
38R Turbo
Recon LED Tailights
2008 tailgate
Backup Camera
2005 Grill
2005 Headlights
Coolant Filter
Bedrug
LED Bed Lighting
post #5 of 11 Old 07-29-2014, 12:28 PM
Quoted: 143 Post(s)
3 relays though? Wouldn't 2 do?
You couldn't just take the power coming from the AC clutch and let it ground through the TC activation and supply the fan at the NC side of it? (as the "interrupt") Then just have another relay to only supply that Fan Power when the clutch is powered before it...
bubba57-chevy likes this.
NoRalPh is offline
post #6 of 11 Old 07-29-2014, 12:37 PM Thread Starter
KISS principal!!! I usually make things more complicated, when I really don't want to.
AIS Intake
DI Tune
38R Turbo
Recon LED Tailights
2008 tailgate
Backup Camera
2005 Grill
2005 Headlights
Coolant Filter
Bedrug
LED Bed Lighting
post #7 of 11 Old 07-29-2014, 04:48 PM
Quoted: 143 Post(s)
Yea, I'm a Big KISS fan (not the Band.... )
I was really Rackin' my Brain trying to figure how to do it with One.
NoRalPh is offline
post #8 of 11 Old 07-29-2014, 05:24 PM
Rodslinger's B1TCH
i wouldn't bother with all that. do it the standard way with a temp sensor in the rad and keep it simple. once you get moving, temp drops, fan shuts off
mine is the same way, warms up a little at idle while not moving. i think i might do the electric fan in front of the condensor also. it would help the trans cooler out too.
steve604 is offline
post #9 of 11 Old 07-29-2014, 05:26 PM
Rodslinger's B1TCH
and i've read about others fixing the same a/c problem with a new condensor. i hate taking the truck to a mechanic to discharge and recharge though.
steve604 is offline
post #10 of 11 Old 07-29-2014, 06:41 PM
Joel's Avatar
Quoted: 10 Post(s)
Can we run an electric fan clutch from a 6.0?
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
Tags
air conditioner , electric fan , torque converter
