Gear ratio for a 7.3 - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 19 Old 07-28-2014, 12:23 PM Thread Starter
diesel22s's Avatar
I have an early 99 4x4 extended cab powerstroke and I am in the process of building a 4x4 crew cab out of it. My donor truck has a limited slip 4.10 gear ratio rear end, my truck now has an open 3.73 rear end. The truck has a 4 inch lift with 35 inch tires and a 6 speed trans. Would the 4.10 be too low of a gear ratio? I would really like the limited slip, but if I do that I still have to find a front axle of the same ratio. Not sure if I should even jack with it, just wanted some opinions. Thanks
diesel22s is offline
post #2 of 19 Old 07-28-2014, 01:33 PM
sbluke55's Avatar
Quoted: 575 Post(s)
Garage
I would do the 4.10. It would be just about right.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 19 Old 07-28-2014, 01:46 PM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
with 35's the "correct" gear is 4:88's so 4:10's are a step in the right direction.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #4 of 19 Old 07-28-2014, 04:44 PM Thread Starter
diesel22s's Avatar
I'm just worried about turning too many rpm's at 75 or 80. Since that's what it seems all the highways are goin too.
post #5 of 19 Old 07-28-2014, 10:26 PM
JSchuricht's Avatar
4.10 is perfect for 35" tires. It's about the closest final drive you can get to 3.73 with stock tires. My 95 with 4.10's, 35" tires and a ZF6 is around 68mph at 2000RPM.
JSchuricht is offline
The Following User Says Thank You to JSchuricht For This Useful Post:
diesel22s (07-29-2014)
post #6 of 19 Old 07-29-2014, 02:04 AM Thread Starter
diesel22s's Avatar
Ok, thanks for the help. I think I will give it a try when I get this build done and see how she does.
post #7 of 19 Old 07-29-2014, 03:15 AM
Zaairman's Avatar
Quoted: 12 Post(s)
Whoa... who's math is that?
I have stock 3.73s with 35s and a 4r110... 77-78 MPH on GPS is 2000 RPM. Its nice unloaded. I'd want 4.10s if I towed heavy often.
nuthinbutfords likes this.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #8 of 19 Old 07-29-2014, 04:01 AM Thread Starter
diesel22s's Avatar
If it was still my daily driver I probably wouldn't mess with it, but like you said, when towing I think it will do a lot better.
post #9 of 19 Old 07-29-2014, 04:11 AM
sbluke55's Avatar
Quoted: 575 Post(s)
Garage
Being a standard I would do the 4.10 like I said above. I have a standard and 35" and I really have to lug the motor a lot on take off and it's kinda smokey. Having gears to high will cause it to be very laggy on take off.
01 f-250, Standard
sbluke55 is offline
The Following User Says Thank You to sbluke55 For This Useful Post:
post #10 of 19 Old 07-29-2014, 08:43 AM
Quoted: 29 Post(s)
I run 35's with my stock 3.73's. Tow 8K lbs often and love the combo.
2000 RPM's and im at 70 MPH. I pull most grades in 6th gear, only reason i ever downshift is cause of EGT's getting too hot.
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
