Vibration after leveling kit - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-28-2014, 10:23 AM Thread Starter
Ford Cowboy's Avatar
Quoted: 5 Post(s)
Had the leveling kit and tires on truck for a couple months now. Since day one I noticed that at take off and when slowing down there are vibrations you can feel through the floor board. I thought at first that maybe it was my new mud tires but now I'm not real sure. Seems like it might be getting worse. I also noticed that if I flex the front suspension any I get a popping that I can hear and feel through the floorboard. My shocks are new, so the only thing I can think that it might be is a sway bar end link? Any suggestions?? Thanks
cummin is the mess left behind by strokin!!
2000 7.3l f350 4x4 cclb psd. 4r100 trans.Ranchhand everything! 6637 intake, zoodad mod, custom big rig runnin lights, ccv mod, RR boots and plenum inserts, foil delete, EV2 gauges, edge cts, tuff country 2.5" leveling kit, X codes, 315/75r16 coopers, 08 mirrors, 6.0 trans cooler, tgc dual steering stabilizer, fabtech adj. trac bar, mbrp 5" turbo back straight pipe with 8" tip, php 6pos, ssbc brakes, ebpv delete, cat elc 100,xxx
Ford Cowboy is offline
post #2 of 8 Old 07-28-2014, 01:08 PM
03ranger30's Avatar
The vibration sounds like the tires, my dad's jeep does the same thing. I'm not sure about the popping sound however.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #3 of 8 Old 07-28-2014, 04:24 PM
After the lift you need to drop the carrier bearing. just shim the carrier bearing for vibration. For the popping sound check your stabilizer links.
ozzy 2002 psd is offline
post #4 of 8 Old 07-28-2014, 05:19 PM
sbluke55's Avatar
Quoted: 589 Post(s)
Garage
Most leveling kits don't mess with the rear so there is no need to drop the carrier bearing. Popping is sway bar bushings or sway bar end links or ball joints.
For the vibration. Do you feel it in the steering wheel or in the seat?
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #5 of 8 Old 07-28-2014, 06:02 PM Thread Starter
Quoted: 5 Post(s)
Front end was rebuilt last summer, new ball joints etc. the vibration is only felt in the floor. Once I get rolling the vibration goes away. When I slow down I feel the vibration right until I make a complete stop. It sounds like the tires humming, so maybe that's it . I'm thinking I need drop sway bar end links. They are pulled way up towards the frame. There doesn't seem to be much room for articulation in the stock end links since the leveling kit and codes were installed. What do y'all think?
post #6 of 8 Old 07-28-2014, 06:33 PM
sbluke55's Avatar
Quoted: 589 Post(s)
Garage
Have you checked your u joints? I'm still saying sway bar bushings where the bar is attached to the axle are shot.
01 f-250, Standard
sbluke55 is offline
post #7 of 8 Old 07-28-2014, 06:41 PM Thread Starter
Quoted: 5 Post(s)
I'll have to get up there and check. Can u buy greaseable sway bar bushings? Thought I'd seen some awhile back
post #8 of 8 Old 07-28-2014, 07:34 PM
sbluke55's Avatar
Quoted: 589 Post(s)
Garage
I recommend energy suspension
01 f-250, Standard
sbluke55 is offline
