adjusting ebrake? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-25-2014, 09:56 AM Thread Starter
Quoted: 3 Post(s)
adjusting ebrake?
So have the rear of the truck on jack stands truck in Neutral and damn I can barley turn the hubs by hand as I'm tuning the transfer case and both axles... how can you do the drag adjustment on these?
Thank you!
2001 F-350 4x4 7.3
2015 AXIS A24 surf boat
2012 Keystone Outback Travel trailer
r33pwrd is offline
post #2 of 4 Old 07-25-2014, 11:05 AM
Quoted: 3 Post(s)
There is a port on the backside of the hub where you can see a splined knob. Use a screwdriver to push the splines and that will adjust the e-brake pads tighter or looser. I'll see if I can get down and take a pic of mine so you know what to look for.
2002 F-250 CCSB
4x4
ZF-6
Banks Cold Air Intake
TS-6 pos chip canned tunes
MBRP 4" turbo-back
blkdrgn42 is offline
post #3 of 4 Old 07-25-2014, 11:07 AM Thread Starter
Quoted: 3 Post(s)
no need for a picture... I had that part figured out just could not spin the hub. Pulled axle. Now if the damn rotor on the other side would come off
2001 F-350 4x4 7.3
r33pwrd is offline
post #4 of 4 Old 07-25-2014, 11:25 AM
sbluke55's Avatar
Quoted: 553 Post(s)
Garage
You probably have to loosen the star adjuster on the parking brake drum to get it off
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
