speedo probs - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-25-2014, 05:05 AM Thread Starter
speedo probs
The speedo is not working in my 1999 f250. all other guages work, and ive replaced the speed sensor on the rear end and that didnt work. Any help would be much appreciated.
z13976 is offline
post #2 of 5 Old 07-25-2014, 06:23 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Have you pulled the cluster and checked that harness?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 5 Old 07-25-2014, 10:04 AM
StrokinAlaska's Avatar
Does your o.d light blink when she isn't working
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
post #4 of 5 Old 07-25-2014, 06:28 PM Thread Starter
I havnt pulled the cluster yet, that was what i was trying to avoid, and yes the OD switch flashes constantly.
z13976 is offline
post #5 of 5 Old 07-25-2014, 06:40 PM
On your driver side wheel well near the firewall under your intake, there is a gray plug coming up from the frame etc. Check the side facing the ground for a loose, cut, chafed wire or anything like that. That was my issue after I changed the vss in the rest hump. Slapped myself for not seeing a wire issue
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
