Did the foil delete.. Was fun - Ford Powerstroke Diesel Forum
 3Likes
  • 3 Post By Go0se
post #1 of 7 Old 07-23-2014, 02:12 PM Thread Starter
Today I had time to remove the nasty looking foil on the tubes. Was fairly easy. Had some paint thinner and a steel brush. Took about 10 mins to remove all that poop. Then painted the tubes red. Woo! Always fun working on the f350.
I cleaned the engine bay. But after looking at this picture, a more thorough job is in store.
hansel, Joel and Eco Taxi like this.
Go0se is offline
post #2 of 7 Old 07-23-2014, 06:34 PM
Joel's Avatar
Quoted: 10 Post(s)
Looks a lot nicer than mine does. Good job.
Take off the spider and wire wheel it. I did that on another guys truck and painted his pipes red and it looked really sharp
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 7 Old 07-23-2014, 07:24 PM
hansel's Avatar
Quoted: 99 Post(s)
I just did mine the other day but I just painted mine a flat black for now, but someday I will pull both out and do them both again in a glossy color.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #4 of 7 Old 07-23-2014, 10:26 PM
Wolfesscythe's Avatar
Quoted: 2 Post(s)
Is the foil delete overly loud? I'd like to do mine, but I'm not 100% on rather or not I'll like the sound.
2001 6-Speed F250 SCLB - South Bend SFDD250-6 Dual Disc Clutch - 7.3 with DIY 6637 - Diamond Eye Turbo-back 4 inch straight - TS 6-Pos PHP Tunes - Billet X-Wheel - Foil Delete | 1988 5-Speed F250 SCLB - 7.3 IDI - Stock
Wolfesscythe is offline
post #5 of 7 Old 07-24-2014, 03:04 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
What do you use to paint the pipes with?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 7 Old 07-24-2014, 05:47 AM
Gunner
GunnerB's Avatar
Looks good! I personally limit myself to general cleanliness and fixing broke stuff when it comes to engine compartments.
2003 F250 7.3L CC XLT SB
AIS Intake
4.5" ICON Lift
Pre-Pump/Coolant/Transmission Filter
PHP Hydra
6.0L Cooler
ISSPRO EGT/BOOST/TRANS
B&W Turnoverball
Firestone Airbags
Warn Premium Hubs
Cobra 29 LX BT
2002 EX LIMITED 7.3L
DS Trans Cooler
Bilsteins
GunnerB is offline
post #7 of 7 Old 07-24-2014, 06:14 AM
hansel's Avatar
Quoted: 99 Post(s)
I high temp paint like for your BBQ grill
You can hear a slightly higher whistle but it's not really bad, nothing the radio won't drown out.
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
