Need some input from the Guru's. - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-22-2014, 04:34 PM Thread Starter
Brace yourselves, this is going to be a little long but i am looking for some input and advice. Alright i have recently bought a 40' fifth wheel dry weight of 13 500 gross of 18K. My truck is an F250 CCSB, mods in my sig. It towed it very well, even got cut off at 55mph and stopped with plenty of space safely. I am not concerned with the trucks ability to move or even stop the trailer. I have the proper commercial licenses to drive a vehicle that heavy in California as well, however my truck is over its legal limit. Now i could swap in a dually rear axle which would be relatively straight forward and for appearances sake i would be a 1 ton, i even have a matching dana 60 up front, but if for some reason they throw me on a scale i will be well over my maximum, empty i am about 1500lbs over and typically i would probably be 3500 over. I pack light but the trailer is now my home and i have a harley and a tool box in the rear.
So enter my newish plan, and what i am looking for opinions on. The similar year f450 has a gross of 26K, 6K over my 250 giving me the need weight limits. The 450 would also boast a larger frame, axles and brakes. However i have put considerable time and money into the modifications of my truck and it is a crew cab as well which i would like to retain. The engine transmission and transfer case on the 250 is the same as the 3/4/550 so i could swap it over and be solid. My engine has more power, good EGT's a higher rated clutch and a newer trans. My biggest question is the cab swap. I have heard that the frame rails are narrower on the 450s. With that being said would the cab swap still be as simple as just lining up the body mounts and bolting it on? I know that i would need to have additional body mounts added for the crew cab, how difficult would that be? I am looking at 450s with a similar wheelbase so that i will have enough clearance.
Any input is appreciated. I know this may be a little over the top so please only comment if you have something constructive. Also please dont just tell me to buy a medium or heavy duty truck either, i dont want to take that route just yet. Thanks again
2000 F250 CCSB 7.3 PSD 6 Speed CFM Intake Manifold AFM Stage 2 Intake Snow Performance Water/Methanol Injection 160/100 Injectors GTP38R Adrenaline HPOP 203* Thermostat Air Dog II Gear Vendors Over/Underddrive 450HP Clutch 4.88 Gears ARB Lockers Mishimoto Intercooler Turbomaster Wastegate Controller 4" Turbo Back Exhaust DP Tuner Icon 4" Lift 37" Procomp Mud Terrains Fabtech Tration Bars
wallace2000 is offline
post #2 of 7 Old 07-22-2014, 04:57 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
You can buy a newer 450 roller crew cab long box Dually and even have the coil sprung front, as far as frame being more narrow I believe that's only behind the cab, the cabs are all the same (as in RC is a RC, cc is a cc, and ec is an ec) this sounds like an interesting way to go about keeping "your" truck and still hauling the same, but good luck and keep us posted on a build
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 7 Old 07-22-2014, 06:03 PM
Shadowfax's Avatar
Quoted: 13 Post(s)
If you swapped your cab and kept your vin# wouldn't they check it and say you are still over weight? If you are worried about the legality part it seems like you'd have to use the cab/vin for the 4/550.
2015 f350 lariat
2003 Jetta TDI 5spd
Shadowfax is online now
post #4 of 7 Old 07-22-2014, 06:18 PM Thread Starter
That's very true. I would use the the Vin from what would be the donor truck. I would register that one in my name. I would have to swap the Vin plates in the cab which I assume could cause some small issues but I doubt it would be a big deal seeing as how in the end it would only really be a cab swap
post #5 of 7 Old 07-23-2014, 04:58 AM
Montstroke's Avatar
Move outta Cali
J/K couldn't resist.
2001 F250 CCSB
Less than cold air intake
RR Billet Wheel
EBPV gone
AIH gone
Turbo back 4" MBRP muffled
6 PHP tunes
315's with Zone level kit
On board air
Suspension air bags
Montstroke is offline
post #6 of 7 Old 07-23-2014, 05:47 AM Thread Starter
Haha. I'm with you there. The truck is registered in Georgia, which funny enough leave my GVWR blank on my registration.....
post #7 of 7 Old 07-23-2014, 01:53 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I kept my trucks registered in ga back when I lived in so cal too lol, never once had a problem towing there into or out of the state line (which is like entering a whole different country when you enter)
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
