Trying to figure out what all i have under the hood?? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-21-2014, 02:30 PM Thread Starter
Ive had the truck awhile but we bought it with somewhere in the neighborhood of 160k at that point it got a new transmission right before we bought it.(now has 298k) It was used for hauling horses around the country, but its only seen daily driving since then with only a tow every now and then, now i think ive figured out they had done a few things to it but Im not sure. So I have taken some pictures and in hopes some of you can help me out so i know what i have as i go about my various upgrades id like to do!
Is this an upgraded turbo by Garrett or is it stock and Garrett makes them?? Also what is that red wire?
What is this green wire??
Now for underneath looking at the exhaust i know it has maganflow muffler and duals coming out the back because we had that put on but is this the Cat? Its an early 99 so it is supposed to have one but couldnt tell if this was it or not since i really have no clue what they look like lol
Im sure with some pictures and googling i could figure out what this is but i figured id post it anyways first what is this and second sohuld i be worried about the liquid that seems to have coated the outside of it?
Here are some more pics just in case you see something odd! Does it seem there is a lot of rust on the frame from the few pics you can see, its in Texas but idk where it might have been hauled around, if it is alot is there anything i should do to help stop it and prevent more? Thanks!!
e99 F-350 Crew Cab, Stock at the moment, 290k+ miles, shes been wrecked, stolen, torn apart. Still trucking and plenty of mods to come her way!
Lurch350 is offline
post #2 of 6 Old 07-21-2014, 03:40 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It looks stock, the red tube goes to the blow off valve, look up red tube mod, explains what it does and how to disable it if wanted, the "cat" or 3rd pik is indeed your catalytic converter, remove if desired, the 4th pik seems like the transmission , the "fluid" on it is probably road grime and oil mix, clean it off, make note and see if anything leaks on or off it in the near future, and your frame seems fine, but to prevent and remove what's currently there, wire wheel it and coat it with POR-15 to prevent anymore from forming
Welcome to the org
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 07-21-2014, 04:11 PM
goats's Avatar
Quoted: 2 Post(s)
Looks like a bone stock early 99
goats is offline
post #4 of 6 Old 07-21-2014, 04:35 PM
Quoted: 3 Post(s)
blow off valve mentioned before = wastegate
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #5 of 6 Old 07-21-2014, 04:48 PM Thread Starter
Alright then just wanted to make sure it was stock and learn what im looking at as i go, didnt know garrett made the stock turbos!
Thanks guys!
Lurch350 is offline
post #6 of 6 Old 07-21-2014, 06:02 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
The make all of them for fords afaik, at least for the 7.3 and pretty sure the 6.0 too
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
