Help with 07 headlight conversion - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-21-2014, 10:55 AM Thread Starter
lcducote's Avatar
Quoted: 4 Post(s)
What's the best way to get the turn signal bulb unplugged? Having some trouble there. And does anyone have the part number for clips to secure the too of the headlight? Can I get them at napa? Thanks
2002 F-250 POWERSTROKE 4X4
BANKS 4" Turbo-Back w/ Power Elbow
Converted from 3/4 to 1TON
Napa 6637 DIY Intake
6.0 Trans. Cooler
Dipricol Gauges
Warn Hubs
TW 6 Pos.
And Some Other Boring Stuff
THANK GOD FOR YOUR BLESSINGS EVERYDAY
lcducote is offline
post #2 of 4 Old 07-21-2014, 11:07 AM
heisman01's Avatar
Quoted: 53 Post(s)
It should just twist out, the clips you can find at lowes or home depot for a lot cheaper then napa.
DD- 11 6.7 scsb: sct4 gearhead tunes, 4" dpb axle dump exhaust, 2.5 level, fox shocks, no limit egr delete, no limit stage 2 intake, STT PRO 295/65r20, black fuel couplers
sold- 00 7.3 modded to the end.
heisman01 is offline
post #3 of 4 Old 07-21-2014, 12:38 PM Thread Starter
lcducote's Avatar
Quoted: 4 Post(s)
Napa is the only store for 100 miles so I'm kinda stuck with them haha. Just wanted to know if I could get them there. I meant just the gray plastic piece that plugs into the wiring harness. Can't seem to get them out
6.0 Trans. Cooler
Dipricol Gauges
Warn Hubs
TW 6 Pos.
lcducote is offline
post #4 of 4 Old 07-21-2014, 06:35 PM
heisman01's Avatar
Quoted: 53 Post(s)
The pig tail? It has a retainer that you have to pry back and will probably break, all of mine did and I just hard wired everything together.
Any style retaining clip will work really or even a zip tie
