Long Bed Camper Top. What Will Work? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-20-2014, 04:10 PM Thread Starter
Wolfesscythe's Avatar
Quoted: 2 Post(s)
Planning on doing some travelling in the fall, so I'm trying to get a decent camper top to keep my baggage dry and stuff.
I've never dealt in camper tops, so I'm not real sure what will fit and what won't. Are they fairly universal between trucks of similar sizes? (I.E, Ford F150, F250, F350 long beds, or Ford/Dodge/Chevy long bed full size trucks.)
Thanks for the info ahead of time.
2001 6-Speed F250 SCLB - South Bend SFDD250-6 Dual Disc Clutch - 7.3 with DIY 6637 - Diamond Eye Turbo-back 4 inch straight - TS 6-Pos PHP Tunes - Billet X-Wheel - Foil Delete | 1988 5-Speed F250 SCLB - 7.3 IDI - Stock
Wolfesscythe is offline
post #2 of 9 Old 07-20-2014, 05:07 PM
If they are for an 8ft bed it should be good, my H&H camper shell on my longbed is awesome!
E99 F250 XLT SuperCab 4x4 3.73 gears, 213k and climbing, ZF6 trans w/ 1944-60K SB Clutch/Flywheel, 6637 filter, muffler/cat delete w/ 5 inch tip, PHP Hydra, 4 gauge pod(EGT, EOT, FUEL PSI, BOOST), 12000 lb Warn Winch, 07 headlights/grill, 6k HID kit, Bushwhacker pocket style fender flares, Pioneer 7" touchscreen, 2.5 inch leveling kit with 315/75/16 General AT2s on stock 16 bullets, HPX
Next up: Rebuild Kit and Billet Wheel, Fixing E-brake so I can park on hills!
Tow51Stang is offline
post #3 of 9 Old 07-20-2014, 05:21 PM
Raul@Stealth Automotive's Avatar
not all manufacturers are universal. so i would check to make sure it fits. I have a ARE on my truck and i really like it.
Raul@Stealth Automotive is offline
post #4 of 9 Old 07-20-2014, 05:38 PM Thread Starter
Quoted: 2 Post(s)
Also, assuming it's fiberglass. What do they do for your fuel efficiency? Better or worse? And what is the cheapest way to change the color? I was thinking that dipping it might be the best choice.
post #5 of 9 Old 07-20-2014, 06:34 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The paint color is all about how you feel mismatching, as far as fit EVERY Superduty (same bed size anyway) will fit, Chevy and dodge are off in length and with of every year, obs is a bit different, but super duties are a size of thier own, just check your local CL, it's one of those things few people buy, and even more don't want
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 9 Old 07-20-2014, 07:18 PM
sbluke55's Avatar
Quoted: 590 Post(s)
Garage
Look at Craig's list and used car lots. They usually have a pile of them in the back that hey pull off before reselling the truck. That's where I've picked up a few.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #7 of 9 Old 07-20-2014, 08:55 PM
Rodslinger's B1TCH
the superduty cab is taller than anything else. you need a canopy meant for a superduty if you want it to look decent. other ones will still fit but most won't look right.
steve604 is offline
post #8 of 9 Old 07-20-2014, 09:41 PM Thread Starter
Quoted: 2 Post(s)
Never thought about checking used car dealerships. I bet they'd get rid of one for pretty cheap.
post #9 of 9 Old 07-21-2014, 03:58 AM
sbluke55's Avatar
Quoted: 590 Post(s)
Garage
I wouldn't say cheap coming from a used car dealership. Usually they run around $500 but compared to $2k new it's not bad.
01 f-250, Standard
sbluke55 is offline
