New truck issues showing up - Ford Powerstroke Diesel Forum
post #1 of 21 Old 07-20-2014, 04:52 PM Thread Starter
Hi I am about at my wits end with a new to me truck. It is 1999 f250 with 156000 miles. My current issues are that when it idles it sounds as though it is a big block cam. My ford mechanic thinks it has bigger injectors in it. Does this sound right? Also when it shifts down from overdrive it will slam into gear causing a jerk. I was wondering if all of this is due to not being properly tuned with a chip.
Dieselsmoke 398 is offline
post #2 of 21 Old 07-20-2014, 05:01 PM
Well if you have aftermarket injectors and not a tune, yes it will cause all kinds of problems like this. Best thing to do is pull them and send them to a place like Rosewood to get tested fully and check your UVCH wires when you pull the valve covers for any corrosion. Any codes being thrown? You need a good scanner like AutoEnginuity or something similar.
E99 F250 XLT SuperCab 4x4 3.73 gears, 213k and climbing, ZF6 trans w/ 1944-60K SB Clutch/Flywheel, 6637 filter, muffler/cat delete w/ 5 inch tip, PHP Hydra, 4 gauge pod(EGT, EOT, FUEL PSI, BOOST), 12000 lb Warn Winch, 07 headlights/grill, 6k HID kit, Bushwhacker pocket style fender flares, Pioneer 7" touchscreen, 2.5 inch leveling kit with 315/75/16 General AT2s on stock 16 bullets, HPX
Next up: Rebuild Kit and Billet Wheel, Fixing E-brake so I can park on hills!
Tow51Stang is offline
post #3 of 21 Old 07-20-2014, 05:21 PM Thread Starter
I was told it has new uvch and they replaced the injector orings. It isn't throwing any codes. I finally got the eot sensor fixed and ebpv sensor and tube. It is almost as if it runs cold. It will idle at 900 rpm when I am stopped at stop sign.
post #4 of 21 Old 07-20-2014, 05:51 PM
I would check the icp and ipr next and have it scanned for any codes from Ford or a good scanner. If all that checks out then I'd be pulling the injectors
post #5 of 21 Old 07-20-2014, 06:02 PM Thread Starter
Icp is brand new and no codes after it was put in at ford except for the eot sensor which I fixed with a sensor and pigtail. I am wondering if I would be money ahead to just get new injectors. I am on the fence about keeping the truck since it needs body work from rust issues. Nothing like living in north east Indiana
post #6 of 21 Old 07-20-2014, 06:05 PM
I'd send out injectors to Rosewood
post #7 of 21 Old 07-20-2014, 06:16 PM
Quoted: 27 Post(s)
If the truck has been maintained decently you got plenty life left in those injectors. Really need a good scan tool. Your accelerator pedal position switch could be acting up causing a high idle. Idk about other injector builders but mine have 160/30 etched on the injector hold down. Even than if they were anything other than stock I'd probably still send them all off to a reputable builder and have them gone through for peace of mind.
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
post #8 of 21 Old 07-20-2014, 06:44 PM
How do u like your 160/30? Much better than stock?
post #9 of 21 Old 07-20-2014, 06:59 PM
Quoted: 27 Post(s)
Yea they're definitely better than stock. I'm still running stock turbo and wheel and there is a little lag. If I give it to much throttle leaving a stop and making a turn it will break loose as soon as the turbo lights lol. Not sure how far I could spin them as I haven't cared to try. Should be rebuilding turbo and installing a ww2 this coming weekend as well as a few other things while the turbo is out. Once all that is done I'll probably be taking it up to PHP for a dyno run and see what she throws down.
-Kris
4'' straight pipe
DIY 6637
38r
post #10 of 21 Old 07-20-2014, 07:04 PM
I want some new injectors so bad but I think if I go 160/30 I'll want larger
The Following User Says Thank You to Tow51Stang For This Useful Post:
powerstroking7.3 (07-21-2014)
