2001 POWERSTROKE VS 2002 POWERSTROKE - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-20-2014, 03:30 PM Thread Starter
Ok guys I have a general question. I had a Ford 2002 F-250 4x4 6 speed. I put a DT tuner on it along with a 4' exhaust. The truck ran like a bear. I use my trucks on a farm and regularly pull a trailer weighing 20,000lbs. The F-250 was just a little light to handle the weights so I bought a 2001 Ford F-450 4x4 6 speed. I put a 4' exhaust and a edge tuner. The truck runs good but not close to the F-250. They both have roughly 80,000 miles. I did notice when driving the 450 the boost never goes much above 15 and that's at 2800 rpms. Any thoughts? I have heard a 02 stock has 275 horsepower and a 01 has 235 horsepower even with the tuner could that be why?Would it be worth it to put a larger turbo and injectors? I do have pretty good mechanical ability just not a lot of experience with powerstrokes. Thanks again.
OLEX310 is offline
post #2 of 8 Old 07-20-2014, 05:15 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Both those motors are identical in every way that would affect power. They are both rated the same too.
Could just simply be up pipe leaks, boost leaks, etc... Maintanence stuff
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 8 Old 07-20-2014, 06:25 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Id guess tuning and gearing, the custom tuned truck should go circles around the edge tuned one, and what gears are they running? 3.73 vs. 4.80?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 8 Old 07-21-2014, 05:12 PM
Vannnce's Avatar
Quoted: 13 Post(s)
x2 with the edge. Whats a DT tuner? Did you by chance mean DP?
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #5 of 8 Old 07-22-2014, 03:14 PM
CSIPSD's Avatar
300hp is 300hp... Doesnt matter on stock injectors.
Gearing is the biggest thing.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #6 of 8 Old 07-22-2014, 04:50 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
But a custom tune is better written then a canned tune either way power wise
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 8 Old 07-22-2014, 06:57 PM
CSIPSD's Avatar
Meh...
Some tuners are better then others, but with stock injectors it is what it is.
Joe
CSIPSD is offline
post #8 of 8 Old 07-22-2014, 10:05 PM
Rodslinger's B1TCH
do you still have the f250? is there still a red tube connected to the waste gate actuator on it? the 450 probably still has the red tube attached which explains the low boost.
steve604 is offline
