Need help with my dying 99 powerstroke - Ford Powerstroke Diesel Forum
post #1 of 31 Old 07-20-2014, 03:19 PM Thread Starter
I need help my 99 powerstroke is having problems it will kill out well driving every so often but I can always start it back up again I thought it was my cps so replaced it, it went about 500 miles and started happening again put another one in , lasted about 300 miles same thing they were cps from oreilly i now tried couple from ford same thing with first one about 300 miles now on my last one and i put that one in and didnt even last 5 miles and doing same thing im i really getting that many bad cps or is there something else wrong any and all thoughts are appreciated.
Powerstrokehopeful is offline
post #2 of 31 Old 07-20-2014, 04:18 PM
Have you checked your icp? Or ipr? Any codes?
E99 F250 XLT SuperCab 4x4 3.73 gears, 213k and climbing, ZF6 trans w/ 1944-60K SB Clutch/Flywheel, 6637 filter, muffler/cat delete w/ 5 inch tip, PHP Hydra, 4 gauge pod(EGT, EOT, FUEL PSI, BOOST), 12000 lb Warn Winch, 07 headlights/grill, 6k HID kit, Bushwhacker pocket style fender flares, Pioneer 7" touchscreen, 2.5 inch leveling kit with 315/75/16 General AT2s on stock 16 bullets, HPX
Next up: Rebuild Kit and Billet Wheel, Fixing E-brake so I can park on hills!
Tow51Stang is offline
post #3 of 31 Old 07-20-2014, 06:37 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Idm???????
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 31 Old 07-20-2014, 06:41 PM
Quoted: 818 Post(s)
I bet you have a wire rubbed raw somewhere. Not enough to blow a fuse but kill a sensor or something to knock out ur engine.
Corey@CNCFAB is offline
post #5 of 31 Old 07-20-2014, 07:50 PM Thread Starter
Iv checked my wires running to my cps and all seem clean and in tacked. Only code other then cam error is a p0603 not sure what that is.
post #6 of 31 Old 07-20-2014, 07:53 PM Thread Starter
I also have an edge tuner on it but iv put it back to stock and the same thing killing on me. I tried unplugging my fuel bowl heater tonight and same thing.
post #7 of 31 Old 07-20-2014, 08:01 PM
Check the icp and ipr(both on top of motor, see if they have oil in the electrical part of the sensor when you pull it) and idm(for water coming in or anything of that sort, behind drivers side fender well)
post #8 of 31 Old 07-20-2014, 08:13 PM Thread Starter
Ok ill check that tomorrow. What would that mean if there is oil in, or water in it?
post #9 of 31 Old 07-20-2014, 08:17 PM
New idm and new sensor wherever it shows, sensors are about $120 each IIRC and swamps sells an upgraded IDM for around $350 I think
post #10 of 31 Old 07-20-2014, 08:25 PM Thread Starter
Ok thanks Ill see what i find.
