Sealing off vaccum lines with warn locking hubs - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By blue99stroker
post #1 of 4 Old 07-19-2014, 04:26 PM Thread Starter
Is there anything that can be damaged by not sealing off the vaccum lines when changing to warn locking hubs?
WhiteSlush is offline
post #2 of 4 Old 07-19-2014, 04:43 PM
BryceB's Avatar
Your vacuum pump will run whenever you put it in 4wd and your vents will switch to defrost.
Easy to plug it. I'm not sure why you wouldn't. I plugged min up under the hood with one 1/4" bolt in the hose off the solenoid.
2001 Ford F-250 SD CCSB 7.3 PSD - AIS Intake, Zoodad,
MBRP 4" XP Series Exhaust w/ Muffler, HD4R100, 26 row Trans Cooler, Fumoto Valve,
285/75R16E BFG AT KO, Pioneer AVIC-Z130BT Nav, BOYO VLT-422C Back Up Camera,
Scangauge II, Glowshift 3 Gauge Pod (EGT,TFT,Boost), PHP FU Chip, Huskyliners, Huskyliner Mud Flaps, Warn Premium Hubs, Riffraff Boots/Clamps/inserts
Dyno'd at Mo's Speed Shop 11/3/12 - 307rwhp / 651rw ft-lbs <<<--- On PHP 120Race tune
BryceB is offline
post #3 of 4 Old 07-19-2014, 05:05 PM
ZMANN's Avatar
Quoted: 1577 Post(s)
remove possible issues
plug the knuckle port ( keeps crap out if the line ever failed)
plug the PVH solenoid Vacuum input ( eliminates possible vacuum leaks if any line or the solenoid fails )
We Miss you Ronnie
ZMANN is offline
post #4 of 4 Old 07-19-2014, 07:21 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
i got rubber caps at napa and just used some silicon to hold them on. been wiring great for 4 years.
GunnerB likes this.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
