changing all the oil - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-18-2014, 05:08 PM Thread Starter
I had a guy tell me when you change your oil, you need to pull the plug and run the motor till the low oil sensor shuts it off so that it gets the oil out of the top of the motor. I think that is crazy, anybody heard of that?
mcfam is offline
post #2 of 6 Old 07-18-2014, 05:39 PM
JSchuricht's Avatar
Your instincts are correct, that guy is crazy. These trucks run off of high pressure oil and are difficult to start/run rough for 50 miles after the system is completely drained. You would just be asking for trouble listening to that guy. The closest thing is taking the plug off the HPOP reservoir and sucking the oil out of it but even that's not necessary.
JSchuricht is offline
post #3 of 6 Old 07-18-2014, 05:54 PM
hansel's Avatar
Quoted: 94 Post(s)
That guy is a "IDIOT"!!!!!!!!!!!
I would not follow any direction from him on anything!!!!!
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #4 of 6 Old 07-18-2014, 10:38 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
i bet he looked at your truck and said, "man it looks like you already deleted your egr"
don't ever do what that guy says lol
there is 15 quarts of oil, if you don't get 1 quart out big deal. it all gets recirculated.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #5 of 6 Old 07-18-2014, 11:27 PM
Rodslinger's B1TCH
the guy knowns absolutely nothing about the 7.3. there is no low oil sensor and the truck will not even try to run if it's 2 or 3 quarts low.
drain plug out, filter out, fill new filter, install new filter, drain plug back in and pour in about 14 quarts. rotella T6 or any synthetic diesel oil works wonders on these engines. the injectors work much better
steve604 is offline
post #6 of 6 Old 07-20-2014, 11:02 AM
Gunner
GunnerB's Avatar
Have him do it first on his ride...to show you what happens.
2003 F250 7.3L CC XLT SB
AIS Intake
4.5" ICON Lift
Pre-Pump/Coolant/Transmission Filter
PHP Hydra
6.0L Cooler
ISSPRO EGT/BOOST/TRANS
B&W Turnoverball
Firestone Airbags
Warn Premium Hubs
Cobra 29 LX BT
2002 EX LIMITED 7.3L
DS Trans Cooler
Bilsteins
GunnerB is offline
