glowshift shift gages and ts chip - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-18-2014, 07:44 AM Thread Starter
Hey to those that have the ts performance chip any problems with it at all and running it sometimes in 140+ give u any trouble...I'm thinking about getting one...also what ur opinion on glowshift gages?
I have a 2000 f250 4x4 7.3 4 inch turbo back and cold air in take
j729m@aol.com is offline
post #2 of 11 Old 07-18-2014, 08:10 AM
You will hear Glowshift Gauges getting a bad rap on the forum, but I have had mine for two years and I have no complaints.
I have gauges for EGT, Transmisson Temp, Fuel Pressure, and Coolant Pressure.
I had my fuel pressure transducer start getting erratic after about 8 months, I called their customer service and they sent me a new one within days.
What I like best about them is that they have only wires running into the cab and not tubing which could leak inside the cab.
2007 F-350 W/Lariat package
4x4 6.0l diesel engine
Leveling kit and 35 inch tires
Coolant Filter kit
EGR Delete Kit
Glowshift Gauge Pillar Pod (EGT, Trans Temp, Fuel Pressure and Coolant Pressure)
Fuel System Blue Spring Upgrade
SCT Tuner
Diamond Eye 4" stainless steel turbo back exhaust kit
ScanGuage II
Zoodad Mod
Backup Cameras from Tadibrothers.com for both truck and 25' Travel Trailer
DJGut is offline
post #3 of 11 Old 07-18-2014, 08:15 AM
sbluke55's Avatar
Quoted: 590 Post(s)
Garage
Glow shift are junk. They only last around a year. I recommend isspro or autometer. Lots of people run the ts chip without problems. I wouldn't run it on 140 all the time because it's all out fuel and can be really smokey. I have the hydra and I run it on dd 80 all the time. You will need a intake and exhaust to help keep egt's down.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 11 Old 07-18-2014, 08:21 AM Thread Starter
Thanks I have and exaust and intake and I wouldn't run it in 140 all the time but I wanted to no what it would do to ur truck if u hit it once and a while
post #5 of 11 Old 07-18-2014, 08:26 AM
sbluke55's Avatar
Quoted: 590 Post(s)
Garage
It would hurt it every once in a while. Just watch your egt's. I'd get a billet compressor wheel also. It will help with turbo surge and add a few hp. Riff raff sells them for around $200
01 f-250, Standard
sbluke55 is offline
post #6 of 11 Old 07-18-2014, 08:29 AM Thread Starter
That's on the list of stuff to get.I'm not haveing problems with surge now but I want to fix it be fore it happens
post #7 of 11 Old 07-18-2014, 08:44 AM
sbluke55's Avatar
Quoted: 590 Post(s)
Garage
Get a hold of hucorey on this forum. He can get you gauges with a discount for being a member.
01 f-250, Standard
sbluke55 is offline
post #8 of 11 Old 07-18-2014, 08:51 AM Thread Starter
Okay thank you
2000 f250 7.3 4x4
33 dick cepek fun country's
4" turbo back Dimond eye
Summit in take
post #9 of 11 Old 07-19-2014, 05:48 AM
Jerrybizzle's Avatar
Quoted: 24 Post(s)
Don't get the standard ts tunes. Pay the extra for the hydra just for the php tunes and option to get other tuners tunes as well. If you can find a used ts chip, you can get reputable tunes put on it for a reasonable amount.
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
post #10 of 11 Old 07-19-2014, 07:57 PM
Quoted: 862 Post(s)
Feedback Score: 3 reviews
Ive got a couple of Hydra's in stock too if your interested instead of the TS chip. Ive got the TS also.
Corey@CNCFAB is offline
