Got Shocked by My Engine - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-17-2014, 11:13 AM Thread Starter
Quoted: 2 Post(s)
Hey guys been on this site for a few months now and it's been very helpful so thank you all for that, but now I have a question that I haven't been able to come up with any info on. The other day I was working on my truck and I got a little jolt of electricity from it. I was removing the EBPS and I was leaning across the Rad support to reach it and my arm was resting on the engine and I noticed a little tingle from it. This wasn't a real hard shock but enough to feel. Anybody ever experience this or have any ideas what to check. Thanks
2000 F250 CCSB Auto
DIY Intake with Amsoil Filter
Hutch and Harpoon Mods
Hydra
Riff Raff Billet Wheel
Riff Raff Boots
FRX
ISSPRO EV2 Boost, Pyro, and Trans Temp
EBPV Deleted Pedestal and Outlet
Bellowed Up Pipes
4" MBRP
315/75/16s with Add A Leaf
RebelRiderNC is offline
post #2 of 11 Old 07-17-2014, 03:07 PM
Did you check the connections on your glow plug relay to see if you maybe got the jolt from that? There are 2 larger studs on top of it and one of them is hot at all times. They are usually covered with a rubber boot but those tend to rot away over time, leaving a live power stud right on top.
derbybug is offline
The Following User Says Thank You to derbybug For This Useful Post:
RebelRiderNC (07-18-2014)
post #3 of 11 Old 07-17-2014, 03:16 PM
Quoted: 172 Post(s)
Feedback Score: 3 reviews
Yea, you're not going to feel the 12v the GP use. You might, however, feel the 100+v the IDM drives the Injectors with. Thing is, if that voltage was "leaking" out, I'd think the engine would miss...
NoRalPh is offline
The Following User Says Thank You to NoRalPh For This Useful Post:
post #4 of 11 Old 07-17-2014, 03:40 PM
sbluke55's Avatar
Quoted: 575 Post(s)
Garage
Sometimes if you have a good connection you can feel 12v. It happened to me last time I worked on my step dads obs.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #5 of 11 Old 07-17-2014, 03:54 PM
You definitely would feel 12V with a good connection. If the OP touched the GPR with a wrench and then leaned on the block with it he would definitely get a jolt. He didn't say it knocked him over or made his hair stand up, he said he got a little tingle from it. The GPR is a common place to see stray voltage discharging if you are unaware it is there or not careful around it. The IDM would zap the hell out of you if you didn't know what you were doing.
derbybug is offline
post #6 of 11 Old 07-17-2014, 03:57 PM
Quoted: 172 Post(s)
Come On Fellas...
Go grab the + and - of your 1000A battery. Squeeze REAL HARD....
NoRalPh is offline
post #7 of 11 Old 07-17-2014, 04:02 PM
Yup and then put a metal wrench between the battery posts and let me know how that goes
derbybug is offline
post #8 of 11 Old 07-17-2014, 05:55 PM
sbluke55's Avatar
Quoted: 575 Post(s)
Garage
Believe what you want but it happens. Last time it happened to me I was sweating and was covered in grease. Try greasing up your are and lay it across the batt and see what happens.
01 f-250, Standard
post #9 of 11 Old 07-18-2014, 03:20 AM Thread Starter
Quoted: 2 Post(s)
I have also felt a shock from 12v and that's about what this was. It wasn't a very high amp shock though. I got hit by the battery the same day (was in a hurry, not being as careful as I should) and it'll knock you pretty good. And I also was no where near the GPR. Does the IDM have power on it all the time?
2000 F250 CCSB Auto
Hydra
Riff Raff Boots
FRX
Bellowed Up Pipes
4" MBRP
post #10 of 11 Old 07-18-2014, 01:06 PM
Wolfesscythe's Avatar
Quoted: 2 Post(s)
Electronics Engineer here, perhaps I can put the 12V thing to rest. The ONLY way you'll feel 12V is if you've lowered your internal resistance to something it can penetrate. Wet body at the point of contact would do it, but no, in normal circumstances, you will NOT feel 12 volts.
The reason it arcs through the wrench is because you're shortening out the two posts with a metal conductor. The resistance on the wrench is equal to something of around 0-10 ohms. Pretty much qualified as a short, with not enough resistance to matter. The human body (Varies from person to person, and conditions) is somewhere around 5Megohms. That's 5 million ohms. That's around 5 million times the resistance of a wrench.
When arcing a wrench, you still wouldn't feel the shock. Perhaps the burn from the sparks hitting you, but that'd be it. High Voltage allows the carry of electrons from one body to another, current (Amps) determines the amount of power that hits you over a period of time.
Chances are, if you felt the voltage of a battery, it'd kill you. 6milliAmps through your heart can kill you. We're talking 1000Amp batteries...
If you got shocked, and it was just a tingle, my assumption would be that you shorted out a capacitor somewhere, and it discharged through you. I've done that a few times, but not by my truck. Not even sure if there's anything with capacitors in the truck, being that the trucks have a constant DC source connected to it. If you were sweating, you could have felt a 12V source, but it couldn't have been direct.
2001 6-Speed F250 SCLB - South Bend SFDD250-6 Dual Disc Clutch - 7.3 with DIY 6637 - Diamond Eye Turbo-back 4 inch straight - TS 6-Pos PHP Tunes - Billet X-Wheel - Foil Delete | 1988 5-Speed F250 SCLB - 7.3 IDI - Stock
Wolfesscythe is offline
