Muffler Delete opinion.. - Ford Powerstroke Diesel Forum
post #1 of 18 Old 07-16-2014, 12:12 PM Thread Starter
Msp079's Avatar
Quoted: 52 Post(s)
Question Muffler Delete opinion..
Hi All,
Been trying to free up money to buy an exhaust but between bills and life its been a no go....
I am assuming that a stock exhaust on a truck is stainless steel...if so a buddy of mine has a welder for that and I was thinking about just doing a muffler delete pipe to free up some exhaust flow on my stock 01 f250 exhaust.
If it is aluminum which I do believe it is I'm stuck cause his welder can't do aluminum...
Thoughts? Any cheap but good sit to buy from...My truck is a 01 crew cab short bed, i know there is different lengths to get ....I am in Tampa Fl now so can't measure until I get home...
2005 F350 Harley Davidson Edition CCSB SOLD!!!
Icon Vehicle Dynamics 4.5" stage 4 lift, 37x13.5R20 Toyo Open Country M/T, 20x10 Fuel Throttle wheels, ARP headstuds, EGR delete, MBRP 5" powdercoated turbo back exhaust, wicked wheel, Blue spring mod, Mishimoto Radiator, oil cooler, stand tubes and dummy plugs, Sinister Diesel coolant filter, 6.4 banjo, Air Raid air filter, SCT X4 tuner with tunes from Innovative Diesel, EGT, HPOP, fuel pressure A-pillar gauge pod
Msp079 is offline
post #2 of 18 Old 07-16-2014, 12:20 PM
The Exhaust definitely not aluminum. I'm don't think its Stainless either. If it is it's low grade. You can just weld or clamp a piece of standard 3.5'" exhaust pipe in place of the muffler.
2000 F250 CCSB Auto
DIY Intake with Amsoil Filter
Hutch and Harpoon Mods
Hydra
Riff Raff Billet Wheel
Riff Raff Boots
FRX
ISSPRO EV2 Boost, Pyro, and Trans Temp
EBPV Deleted Pedestal and Outlet
Bellowed Up Pipes
4" MBRP
315/75/16s with Add A Leaf
RebelRiderNC is offline
post #3 of 18 Old 07-16-2014, 12:26 PM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
A diamond eye exhaust system only runs $220. Thats from turbo back without muffler. To make things easier just have a muffler shop flair both ends of the delete pipe and clamp it but it's just regular old steel pipe and it going to run $50 plus $20 for clamps.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 18 Old 07-16-2014, 12:43 PM Thread Starter
Msp079's Avatar
Quoted: 52 Post(s)
Just watched a video on youtube of a guy that just used a flex pipe about 30 inches or so....He states its a temp set up but did the job...Any thoughts on that or just go with a muffler delete from a company and if so what company is good?
Msp079 is offline
post #5 of 18 Old 07-16-2014, 12:53 PM
Quoted: 27 Post(s)
$50?
NAPA has 3", 3.5" and 4" all at around $5 to $8 a foot. He should hardly need 3 feet.
I bought 6' of 4" for $45 out the door....
Just buy the length you need from NAPA and have your buddy weld it on. simple, effective and cheap.
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #6 of 18 Old 07-16-2014, 12:59 PM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
Flex pipe is a waste of money. I would do the full turbo back from diamond eye or save up tell you can afford it. IMHO spending $50-$70 on a muffler delete and then spend in money on a full exhaust is a waste. Especially when a full exhaust is $250. If you want a delete pipe just go to your local exhaust shop and get it there.
01 f-250, Standard
sbluke55 is offline
The Following User Says Thank You to sbluke55 For This Useful Post:
700hauler (07-16-2014)
post #7 of 18 Old 07-16-2014, 01:03 PM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
Originally Posted by CarportMechanic View Post
$50?
Buddy of mine wanted to delete the cat and muffler for 4" it was $50 but it was also flaired on both ends because nobody had a welder. Plus $10 eeach for clamps.
01 f-250, Standard
sbluke55 is offline
post #8 of 18 Old 07-16-2014, 03:15 PM Thread Starter
Msp079's Avatar
Quoted: 52 Post(s)
I understand what your saying with a full exhaust being long run cheaper..but I'm trying to do it cheap way for now and free up some flow...
How long does it usually last and can anyone give me a link for a good website to buy from besides like Amazon or summit racing...I was going to use band clamps as well from walker...
Any help guys much appreciated.
Msp079 is offline
post #9 of 18 Old 07-16-2014, 03:54 PM
Macon's Avatar
Your local exhaust shop can get it done and have you out the door in less than 30 minutes, and I wouldn't see it costing more than $40.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #10 of 18 Old 07-16-2014, 03:59 PM Thread Starter
Msp079's Avatar
Quoted: 52 Post(s)
Biggest thing is most dealerships don't have 3.5 in exhaust piping it's all 3" or less
Msp079 is offline
