Leaking Injector - Ford Powerstroke Diesel Forum
post #1 of 14 Old 07-15-2014, 05:35 PM Thread Starter
Leaking Injector
I found a 2000 7.3 power stroke for sale on craigslist that I like. He is asking 5k, it has 243k miles, rebuilt trans, tuned, but he said there is a leaking injector that was diagnosed at a ford dealership. How much would it cost to replace the injector? Is it bad if the truck was driven with a leaking injector?
WickedEvo is offline
post #2 of 14 Old 07-15-2014, 07:02 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Could easily mess up the piston, but replacing an injector is actually kind of easy
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 14 Old 07-15-2014, 07:29 PM Thread Starter
About how much would it cost to have a mechanic do it? Is there any way to tell if the piston is messed up from the leaky injector? The guy said it smokes while its running.
post #4 of 14 Old 07-16-2014, 09:32 AM Thread Starter
Also how much would it cost if i decided to change the injector my self?
post #5 of 14 Old 07-16-2014, 09:58 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
If you did it yourself, it would be 1 injector + o rings, not sure what mechanics charge these days, but roughly $300 if everything came from ford or such
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 14 Old 07-16-2014, 04:35 PM
Joel's Avatar
Quoted: 10 Post(s)
Is it a bad injector or just a leaky injector oring?
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #7 of 14 Old 07-16-2014, 07:18 PM Thread Starter
I'm not sure. I'm more concerned that the engine can messed up. Any more imput on how it can effect the engine?
post #8 of 14 Old 07-16-2014, 08:36 PM
Joel's Avatar
Quoted: 10 Post(s)
Leaking oring won't cause any permanent damage, but could cause a no start or hard start issue, especially when warmed up.
An injector stuck open would dump fuel in and could burn a hole right in the piston. This is far less common though. 7.3 injectors don't seem to fail in that fashion very often
Joel is offline
post #9 of 14 Old 07-16-2014, 08:59 PM Thread Starter
Ok I will have to try to find out more information from the guy. Is there any way to tell if the injector is stuck open? He said it smokes while it runs if that helps at all.
post #10 of 14 Old 07-16-2014, 09:07 PM
Rodslinger's B1TCH
if there was a hole in the piston you would have blowby. search youtube for "7.3 blowby" to see how to check it.
243k and unknown if replaced, i would replace the injectors. a good rebuilt set is about $1300. you could probably find a shop that will charge $400 to replace them and find another that will want to charge you $1000
it's not that bad of a job to do yourself. the hard to reach valve cover bolts are the worst part.
steve604 is offline
