200000 miles - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-15-2014, 10:26 AM Thread Starter
200000 miles
Hello, I have a 2000 excursion with a 7.3l, 4" exhaust with 6"tip, k&n air filter. I recently turned over 200000 miles and I have noticed my fuel milage going down. I used to get 15 pretty much no matter what except when I towed my 34' toyhauler and it would go down to 10. Now I get 12 and 8. I faithfully change the oil (even the top 3 quarts) and the fuel filter. I put in fuel aid every service also. Is there anything I can do to get it back? I was also reading that it is a good idea to flush the motor, but I don't know what to use on a diesel? Someone mentioned the napa engine flush is good. if so do you use only 1 can or more because of the oil capacity?
mcfam is offline
post #2 of 7 Old 07-15-2014, 10:53 AM
Hate stupid people
CloverLeafFarm's Avatar
Quoted: 145 Post(s)
Any performance mods like tuning?
Illiana Strokers DICtator
EFI Live tuned 6.7
CloverLeafFarm is offline
post #3 of 7 Old 07-15-2014, 10:54 AM
Hate stupid people
Quoted: 145 Post(s)
And I'd get rid of the K&N filter, their known to allow dirt to pass through and basically be useless
EFI Live tuned 6.7
post #4 of 7 Old 07-15-2014, 10:55 AM
SuperCrutyPS's Avatar
Quoted: 337 Post(s)
Garage
Congrats on being a member of the 200K club!!
One thing to check would be the brake calipers to see if any of them are dragging. Sometimes the pins that the pads slide on get yuck on them and they limit the movement of the pads.
Have you been using the AC more than usual?
What part of CA do you live in?
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #5 of 7 Old 07-15-2014, 06:31 PM Thread Starter
no, I don't have any mods, but I was thinking of trying one that would help with mpg, any recommendations? what filter would you recommend running? I live in southern ca, Hesperia to be exact. no, I don't run the a/c any more than usual. any other ideas I could check it might just be getting old!!!!
mcfam is offline
post #6 of 7 Old 07-15-2014, 06:55 PM
sbluke55's Avatar
Quoted: 590 Post(s)
Garage
Clean your ebps tube and sensor. YouTube has a few videos.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #7 of 7 Old 07-16-2014, 01:49 PM
Get a 6637 air filter if u can have those in CA. your injectors are probably starting to lose life and that will decrease mileage greatly. Also clean EBPS tube and sensor. And get a Hydra or some type of similar tuner and you should be back near the 20s if all of that was done Including injectors.
E99 F250 XLT SuperCab 4x4 3.73 gears, 213k and climbing, ZF6 trans w/ 1944-60K SB Clutch/Flywheel, 6637 filter, muffler/cat delete w/ 5 inch tip, PHP Hydra, 4 gauge pod(EGT, EOT, FUEL PSI, BOOST), 12000 lb Warn Winch, 07 headlights/grill, 6k HID kit, Bushwhacker pocket style fender flares, Pioneer 7" touchscreen, 2.5 inch leveling kit with 315/75/16 General AT2s on stock 16 bullets, HPX
Next up: Rebuild Kit and Billet Wheel, Fixing E-brake so I can park on hills!
Tow51Stang is offline
