Oil changes and such.. - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-15-2014, 07:18 AM Thread Starter
Msp079's Avatar
Quoted: 52 Post(s)
Thumbs up Oil changes and such..
Hi All..
This time around due to time I am going to bring my truck to the diesel shop for a oil change..They use valvoline premium blue any thoughts on that.....I also always struggle with mpg and did mostly highway and avg 14.3. ...Anything that I can have them look at while I have it down there? I read that there is 2 fuel filters in the fuel tank if so true how much do those usually run to clean all that up....Any suggestions on maintenance or to just check would greatly appreciated!
2005 F350 Harley Davidson Edition CCSB SOLD!!!
Icon Vehicle Dynamics 4.5" stage 4 lift, 37x13.5R20 Toyo Open Country M/T, 20x10 Fuel Throttle wheels, ARP headstuds, EGR delete, MBRP 5" powdercoated turbo back exhaust, wicked wheel, Blue spring mod, Mishimoto Radiator, oil cooler, stand tubes and dummy plugs, Sinister Diesel coolant filter, 6.4 banjo, Air Raid air filter, SCT X4 tuner with tunes from Innovative Diesel, EGT, HPOP, fuel pressure A-pillar gauge pod
Msp079 is offline
post #2 of 9 Old 07-15-2014, 07:28 AM
hansel's Avatar
Quoted: 99 Post(s)
The tank filter's you'r referring too will get plugged up over the years, this is where most guys perform the "hutch mod" which eliminate's those 2 filters and add's an external filter instead. Since I did not want too mess around with mine I had my diesel guy clean those filter and it cost around $250, and he also replaced my broken fuel pick up. If I had a lift and a extra pair of hands I would do it myself but I'm not wrestling with my tank laying in the driveway.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #3 of 9 Old 07-15-2014, 10:51 AM Thread Starter
Msp079's Avatar
Quoted: 52 Post(s)
Thanks pal...I just reading on regulator kit for the fuel bowl..any thoughts on if it's worth the money?
Msp079 is offline
post #4 of 9 Old 07-15-2014, 10:56 AM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
unless you plan on bigger inj's then not worth it
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #5 of 9 Old 07-15-2014, 12:40 PM Thread Starter
Msp079's Avatar
Quoted: 52 Post(s)
Ok good to know...Anything else I should look out for to check or do? Transmission flush..rear different fluid or aftermarket cover...Anything to look at with motor? Just want to get some ideas and put a check list together to keep things fresh and in working order....
Thanks!
Msp079 is offline
post #6 of 9 Old 07-15-2014, 01:14 PM
heykw's Avatar
6.0 trans cooler
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #7 of 9 Old 07-15-2014, 06:22 PM
Not to thread jack but im at the same point (first oil change since ownership) what do you guys suggest?
amerimuscle is offline
post #8 of 9 Old 07-16-2014, 05:00 PM
Do you know what's in there now? Stay with that if you know if not, I use Delo-400 or you can use Rotella T6 like a lot do on here. If your in cold weather I'd go with rotella for easier cold starts
E99 F250 XLT SuperCab 4x4 3.73 gears, 213k and climbing, ZF6 trans w/ 1944-60K SB Clutch/Flywheel, 6637 filter, muffler/cat delete w/ 5 inch tip, PHP Hydra, 4 gauge pod(EGT, EOT, FUEL PSI, BOOST), 12000 lb Warn Winch, 07 headlights/grill, 6k HID kit, Bushwhacker pocket style fender flares, Pioneer 7" touchscreen, 2.5 inch leveling kit with 315/75/16 General AT2s on stock 16 bullets, HPX
Next up: Rebuild Kit and Billet Wheel, Fixing E-brake so I can park on hills!
Tow51Stang is offline
post #9 of 9 Old 07-16-2014, 05:47 PM
alaskan155's Avatar
Quoted: 65 Post(s)
i run mobil delvac 1300 from the local farm store($68 for 5 gallons bucket) with a Motor craft Filter I change it every 5k miles
trans fluid service (mercron/dexron) /Filter if Auto
Valvoline.com > Products > Automatic Transmission Products > Automatic Transmission Fluid > Valvoline® DEX/MERC ATF
is what i have in mine right now
fuel filter on top of the engine.
check ICP for OIL in electrical plug,
glow-plugs(never know if/what the PO installed in it, install ONLY Beru(Motor-craft)
upgrade to Snow plow Relay or White-Rodgers Glow PLug Relay
if >100kmiles diff fluid. and t-case fluid
maybe clean the ebpv sensor tube/replace sensor is mileage is low
just basics, can grease the joints/Driveshaft if needed, but that is where i would start...
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
