Brake lights? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-14-2014, 08:45 AM Thread Starter
awdbare's Avatar
Brake lights?
My brother noticed yesterday that my brake lights on the trailer were not working. Usually a bad connection or a fuse but not this time. So far I have checked both fuse boxes, all the bulbs are fine, connectors are fine, 3rd brake light is good, turn signals work, hazards, running lights, but no brakes?
I also checked for voltage at the brake pedal switch and it has 2 sources of 12v constant. While the pedal is depressed, I get 1 green wire with red line on it that activates and passes current but not thru the other wires.
Also, my truck has a electric brake controller in the cab for a trailer. When I press the button on the side to engage the lights, the brake lights for the truck and the trailer come on?!?!?
Stumped here, any thoughts?
awdbare is offline
post #2 of 5 Old 07-14-2014, 08:56 AM
sbluke55's Avatar
Quoted: 590 Post(s)
Garage
Get a test light and test the 7 way plug. Here's a diagram. Attachment 311442
I would hook your ground up to the frame and have someone step on the brake. You should have power to 6 and 7. Also check the ground on the 7 way by hooking the ground to 1 and touching 4, or 5 or 6 while the brake is pushed.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 5 Old 07-14-2014, 09:05 AM Thread Starter
awdbare's Avatar
No 7 way. Only has a 6 way and a 4 flat. Someone must have switched it over (previous owner or something)
It has always worked fine in the past. This just came about 3 days ago.
Also, I am getting no power to the brake bulb connectors in the tail lights while pedal is depressed. Tested it with meter.
awdbare is offline
post #4 of 5 Old 07-14-2014, 09:20 AM
sbluke55's Avatar
Quoted: 590 Post(s)
Garage
Did you check the trailer light fuses in the under hood fuse box? Touch your meter to both sides of your fuse while the key is on. How did they get the 6 way to fit in the 7 way spot. Shoot a picture so I could see.
01 f-250, Standard
sbluke55 is offline
The Following User Says Thank You to sbluke55 For This Useful Post:
awdbare (07-14-2014)
post #5 of 5 Old 07-14-2014, 06:08 PM Thread Starter
awdbare's Avatar
They didn't put it in the same spot. Someone put a 6 way in one of the holes for the tag plate light. Im not sure why either, I personally would rather have the 7 way but whatever for right now.
I ended up figuring it out. It was the brake light switch all along, I went with a hunch a luckily I was right. For 15 bux it wasn't a bad gamble so I went for it.
Thank you very much for offering up some input !
awdbare is offline
