F250 Winter Driver - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-12-2014, 03:25 PM Thread Starter
F250 Winter Driver
I am considering buying a high mileage 200k +- 99-03 F250 EX Cab SB to use for winter driving (live in mountains), hunting, and towing my bobcat around occasionally. I have had a 2005 cummins, 2001 duramax and a 2010 cummins, but not a F250 yet. Are these trucks still any good with high miles? I have heard they get death wobble, are the front ends expensive to maintain? I am considering these because they can be had pretty cheap but I still need it to be reliable. The other vehicle I am consider is a Tundra of the same era, not as good towing but probably better for winter driving and hunting I would guess.
mdurbahn is offline
post #2 of 4 Old 07-12-2014, 03:35 PM
alaskan155's Avatar
Quoted: 66 Post(s)
there good with high mileage. the 99-03 are leaf springs in the front, so real basic/cheap front end(the balljoints and unit bearings are the most expinsive parts but the dodge and chevies run the same ones....
2002 F250 7.3/JW Tow master 4r100 212k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles, Redhead steering box
alaskan155 is offline
post #3 of 4 Old 07-12-2014, 06:44 PM
Zaairman's Avatar
Quoted: 12 Post(s)
I've never had any death wobble problems in 60k of owning a Super Duty...
As long as it has been maintained, you will be good to go.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #4 of 4 Old 07-14-2014, 03:24 PM
Quoted: 171 Post(s)
The straight axle front end is much stronger and more reliable than the ifs on the Duramax trucks.
00 f250 ext. cab, lb, 4x4, 146,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Duck Commander Mts, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dorman up pipes,IAH delete, ccv mod, 6637 filter, auto meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
