Cant get pitman arm off - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-12-2014, 07:52 AM Thread Starter
Installing a lift kit on 2000 f350. I am trying to remove the stock pitman arm with no luck. I have soaked it in pb blaster, heated it and tried a pitman arm remover and a 5 ton 2 jaw puller. No luck. Any suggestions?
joshp01 is offline
post #2 of 5 Old 07-12-2014, 08:20 AM
ShelbyGuy's Avatar
Quoted: 2 Post(s)
I had the same issues swapping mine out.
While putting pressure on the arm/shaft with the puller, smack it a few times with a big hammer on the side of the pitman arm.
mine popped right off after about an hour of ****ing with it.
Norm
2000 F250 Auto CC SB
270,000
Airaid intake, MBRP 4" exhaust, Swamps 175/146, IH Up pipes, GTP38r, TS/Swamps 6pot switch, Airbags, 6.0 Trans Cooler, OBA, Horns
May start looking into a trans?
ShelbyGuy is offline
post #3 of 5 Old 07-12-2014, 08:40 AM Thread Starter
I cant get the puller to even stay on it is what really sucks
joshp01 is offline
post #4 of 5 Old 07-12-2014, 08:59 AM
tcfd135's Avatar
I had the same problem when i replaced my steering box. I couldn't get a puller to work cause they kept sliding off. I took a 3 lb hammer to it hard for about an hour and a half and it just popped off.
2006 F250 Lariat Crew Cab
4" Turbo Back Exhaust, K&N Intake, SCT, Homemade Coolant Filter, Fab Fours Bumper, B&W Turnover Gooseneck, EGR Delete, Bypass Oil Filter, 2" Lift, 315 70 17 Pro Comp Extreme M/T 2's, 12K Winch, Redhead Steering Gear.
tcfd135 is offline
post #5 of 5 Old 07-12-2014, 06:59 PM Thread Starter
I finally got it. Lots of pressure on the puller, heat it up a bit and beat the living hell out of it. About 20 hits and it came off. Pain in the butt
joshp01 is offline
