I'm having troubles - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 50 Old 07-11-2014, 02:34 PM Thread Starter
Joel's Avatar
Quoted: 10 Post(s)
I'm having troubles
2000 with 160/30's that have been in since October.
Out of the blue it refused to start the other day and got towed here.
ICP maxes out at 300psi at 89.9% DC
So I pulled off the valve covers to look for injector leaks, couldn't see anything
Pressurized the rail with air and couldn't hear anything except a little gurgling in the oil pan.
So must be IPR right? Nope. I put my IPR in his truck and no start. Put his IPR in my truck and she fired right up. So I switched that back.
That leaves the hpop. So I switched the HPOP with a known good one I have and still nothing.
I've noticed that icp doesn't budge from 0psi until the IPR climbs to 89.9% and then the icp slowly climbs until it hits 300+/- psi and stops there.
Do I have to pull injectors one at a time and look for oring tears? Anyone think of anything I'm missing?
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #2 of 50 Old 07-12-2014, 08:17 AM
Did I understand that right?
You put your truck's IPR in your buddy's truck which I assume was running up to that point and it didn't start?
Your buddy's truck's IPR in your truck made your truck fire right up?
Unless I am misreading something it looks like you have a bad IPR.
2001 F350 XLT 4x4 with the offroad package. Ext cab shortbox auto. 7.3 Powerstroke. TransGo shift kit, stock auto hubs, Napa 6637 air filter mod, no chips or tuners yet.
Unplugged is offline
post #3 of 50 Old 07-12-2014, 09:01 AM Thread Starter
Joel's Avatar
Quoted: 10 Post(s)
Sorry, that may have been unclear.
My truck is fine, buddy's truck getting worked on. I ruled out the IPR by swapping them and both work in my truck, neither work in his truck
Joel is offline
post #4 of 50 Old 07-12-2014, 09:35 AM
Rodslinger's B1TCH
this is similar to what your truck was doing a while back right?
steve604 is offline
post #5 of 50 Old 07-12-2014, 10:09 AM
sbluke55's Avatar
Quoted: 624 Post(s)
Garage
I'm having troubles
Have you applied 12v straight to the ipr to rule out wire or PCM problems.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #6 of 50 Old 07-12-2014, 11:02 AM Thread Starter
Joel's Avatar
Quoted: 10 Post(s)
@Steve604 - It's similar to mine, except when my injector o-ring leaked it was very easy to spot by the oil oozing out.
@sbluke55 - I want to try that, but im finding mixed reports of the correct way to do it. i have very close to battery voltage on the one wire, and the other wire is the one that gets the signal from the PCM.
Some say to jump it with 12v, others say its a modulated ground circuit and to ground it out fo close the IPR.
I dont want to wreck it by doing the wrong thing. but thats what I'll try next
Joel is offline
post #7 of 50 Old 07-12-2014, 11:06 AM
The Maddawg
maddawg89's Avatar
Quoted: 308 Post(s)
Feedback Score: 3 reviews
300 seems kinda low on icp to me... have you dead headed the oil rails to check hpop? Is there metal filings in oil filter?
~ The Maddawg
2005 F250 6.0 Powerhouse Lariat
Bully GT Platinum with Quick Tricks
Bully Dog intake
Everything else stock.
Moto Metal 18in rims wrapped in 275/70 Mud Claw Extremes
2003 F250 cclb flat bed.
All stock 7.3 turtle
maddawg89 is offline
post #8 of 50 Old 07-12-2014, 11:23 AM Thread Starter
Joel's Avatar
Quoted: 10 Post(s)
I replaced the hpop.
The fuel has no oil in it. Rails seem to hold air.
I'm thinking it almost has to be wiring.
Joel is offline
post #9 of 50 Old 07-12-2014, 12:37 PM
Rodslinger's B1TCH
i think that a wiring issue would give you associated trouble codes
did you try hitting it with your purse?
steve604 is offline
The Following User Says Thank You to steve604 For This Useful Post:
maddawg89 (07-12-2014)
post #10 of 50 Old 07-12-2014, 01:06 PM
The Maddawg
maddawg89's Avatar
Quoted: 308 Post(s)
There should be DTCs there. ... I wish we could hook our IDS to it and get a good reading on everything that pcm is seeing....
I will talk to my boss about it monday but in the meanwhile I'll keep thinking
~ The Maddawg
Bully Dog intake
