cut stock exhaust to remove?? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 07-11-2014, 05:02 AM Thread Starter
01 4x4 excursion 7.3l, I was reading the instructions for an aftermarket exhaust and in the removal of the stock exhaust part it says to cut the exhaust (multiple times if I remember correctly). Does that sound normal? Can it be taken off by just disassembling it?
amerimuscle is offline
post #2 of 15 Old 07-11-2014, 06:19 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
At this point your better off cutting the stock out, makes dropping it a whole hell of a lot easier, the amount of heat cycles it's seen is up there so the pipes as they fit over each other is gonna be frozen
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 15 Old 07-11-2014, 07:19 AM Thread Starter
I'm just baffled that it won't disassemble? ? So what are the common cut spots?
post #4 of 15 Old 07-11-2014, 07:41 AM
BryceB's Avatar
On my F250 I cut before and after the muffler and at the bottom of the down pipe. It all just slid out then.
2001 Ford F-250 SD CCSB 7.3 PSD - AIS Intake, Zoodad,
MBRP 4" XP Series Exhaust w/ Muffler, HD4R100, 26 row Trans Cooler, Fumoto Valve,
285/75R16E BFG AT KO, Pioneer AVIC-Z130BT Nav, BOYO VLT-422C Back Up Camera,
Scangauge II, Glowshift 3 Gauge Pod (EGT,TFT,Boost), PHP FU Chip, Huskyliners, Huskyliner Mud Flaps, Warn Premium Hubs, Riffraff Boots/Clamps/inserts
Dyno'd at Mo's Speed Shop 11/3/12 - 307rwhp / 651rw ft-lbs <<<--- On PHP 120Race tune
BryceB is offline
post #5 of 15 Old 07-11-2014, 09:12 AM
blue99stroker's Avatar
Quoted: 283 Post(s)
you can cut the down pipe off and the hangers and the rest slides off.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #6 of 15 Old 07-11-2014, 09:19 AM
Ford Cowboy's Avatar
Quoted: 5 Post(s)
3 cuts is all it takes. 2 cuts on either side of the muffler and then one cut as far up on the down pipe as you can get. Make sure you lube your exhaust hangers with some type of lube. I used silicon spray. I just installed an mbrp exhaust a dew days ago. I had the old exhaust out in 30 minutes. Took me an hour to install the new one. Make sure you take the down pipe clamp off the turbo before you cut the down pipe. U don't want jerkin on the turbo while you're cuttin.
cummin is the mess left behind by strokin!!
2000 7.3l f350 4x4 cclb psd. 4r100 trans.Ranchhand everything! 6637 intake, zoodad mod, custom big rig runnin lights, ccv mod, RR boots and plenum inserts, foil delete, EV2 gauges, edge cts, tuff country 2.5" leveling kit, X codes, 315/75r16 coopers, 08 mirrors, 6.0 trans cooler, tgc dual steering stabilizer, fabtech adj. trac bar, mbrp 5" turbo back straight pipe with 8" tip, php 6pos, ssbc brakes, ebpv delete, cat elc 100,xxx
Ford Cowboy is offline
post #7 of 15 Old 07-11-2014, 11:23 AM
Quoted: 14 Post(s)
Cutting the stock off is definitely the way to go. Thats how I have done it on all my vehicles. If you are not putting it back on or selling it who the heck cares how it looks. A good sawzall with good blades are your friend.
When I cut the exhaust up on my 3 series I tried using cheap blades, I ended up eating 3 of them before switching to dewalt blades. Didn't help that the stock exhaust was thick stainless.
Will335i is offline
post #8 of 15 Old 07-11-2014, 11:38 AM Thread Starter
ok ok good info , thanks. Am I lubing the hangers so they don't break under stress from the cutting? and im not sure how much new hardware comes with the new exhaust kit? its an MBRP as well I think the XP series, just wanna know ahead of time what all ill be reusing and what will be discarded.
MBRP Performance Exhaust
post #9 of 15 Old 07-11-2014, 12:11 PM
Quoted: 5 Post(s)
The reason for the lube is so that the old exhaust hangers will come put fairly easy. They can be a bit?$ if they r not lubed up. Your exhaust kit should come with everything you need. All new hangers come pre welded on. All you should have to do is fit the pieces together. That's how it was with my kit.
post #10 of 15 Old 07-11-2014, 12:32 PM
heykw's Avatar
The only thing you should reuse id the black rubber that the hangers slide into
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
